Results 1 to 3 of 3
Thread: parallel or series for more power
    Nov 2011
    ireland
    Question parallel or series for more power
    hi guys the motors in question is nema34
    78mm long
    1.8 step angle
    320n.cm
    80vdc/6.4amps
    2 phase
    4 wires out,
    which would have more power, wired in parallel or wired in series???
    Registered doorknob's Avatar
    Jan 2010
    If I have correctly understood your question, since you have a 4-wire motor you do not have any option in the way that you wire it up.
    Normally the question of bipolar parallel or series wiring of windings comes into play if you have an 8-wire motor.
    Registered James Newton's Avatar
    May 2005
    Yeah, 4 wires is only bipolar, and you have no control over that, but it can be series or parallel bipolar depending on how the mfgr wired it up inside the motor.
    If you do get some motors with more wires, all the options are listed on this page: techref.massmind.org/techref/io/stepper/connections.htm
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
  1. Newbie- What to do? Parallel/Series
    By maintenancemike in forum Stepper Motors and Drives
    Last Post: 02-09-2008, 10:47 AM
  2. Wiring drives (24v power) in series or parallel
    By watsonstudios in forum General Electronics Discussion
    Last Post: 06-29-2007, 06:27 AM
  3. When should I go from series to parallel?
    By Oldmanandhistoy in forum Stepper Motors and Drives
    Last Post: 03-14-2007, 09:26 AM
  4. parallel vs series
    By miro in forum Stepper Motors and Drives
    Last Post: 01-25-2007, 11:52 AM
  5. series or parallel
    By turmite in forum General Electronics Discussion
    Last Post: 12-28-2003, 11:27 PM
