Results 1 to 5 of 5
Thread: please help nema 34 motors no power
    Nov 2011
    ireland
    Unhappy please help nema 34 motors no power
    i have 2, nema double stack 34 stepper motors at 6.5 amps each and 2, driver boards RM B4DB 20v to 50v up to 4.5amp output. now there only driving 1.8mts screws on a plasma table, problem is i used to have a 24v 6.5amps transformer powering the 2 motors and if i grabbed hold of the screw lightly it would stop the motor,, so got a new tranformer today thinking this would be the job,, it is 38 volts 11amps output. so wired it up but still no difference i thought it should be a little better at least, maybe there is something i am missing here ,that needs adjusted, all help would be very appreciated?????
    Registered James Newton's Avatar
    May 2005
    Sounds like a driver problem. A quick search for RM B4DB didn't turn up anything. What driver is that? Are you sure you have it set for max power output?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Nov 2011
    ireland
    hey james i got the motors and drivers from www.rhonmac.co.uk there RM 4DB driver board has a selection of dip switches on the side i have them set at full amps output and have tried all different pulses/rev settings but no good also tried changing the amp settings incase the on indicator was on the wrong side, its bit down hearting to buy stuff and find its not right, but its a great learning curve!!! is it correct the volts input to the motor is the motor speed,, and the amps input to the motor is the motors power maybe i need 50 volts input but then again the motors had no extra power with the transformer changed??
    Nov 2011
    ireland
    Oh another question which would be better or have more power ,parallel or series on the 2 phase 4 wire nema motors??
    May 2005
    All the connection options (and the pro's and con's) are listed on this web page: techref.massmind.org/techref/io/stepper/connections.htm
    The rhonmac.co.uk web page doesn't seem to what to load for me... not right now anyway...
    That certainly sounds like a bad driver... have you contacted their technical support?
    1. Stepper motors NEMA 23 & 34
      By all4anm in forum EBAY ADS
      Last Post: 03-20-2010, 06:58 PM
    2. nema 23 vs nema 34. how much power do I need?
      By will gilmore in forum Vertical Mill, Lathe Project Log
      Last Post: 08-20-2009, 10:13 PM
    3. Problem- Nema 23 stepper motors
      By nenetwork in forum Stepper Motors and Drives
      Last Post: 04-24-2009, 01:46 PM
    4. nema motors
      By radex in forum General Electronics Discussion
      Last Post: 07-23-2008, 12:22 AM
    5. Need Help!- Wiring Nema 23 Motors
      By jamesrm in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-29-2008, 10:23 AM
