Page 10 of 10 FirstFirst ... 78910
Results 109 to 113 of 113
Thread: viable stepper driver?
  1. #109
    Nov 2011
    Netherlands
    hey john
    i found out the printer port was fine, but since i was running 64bit win7, mach3 couldnt controll the port. so i made a partition on my hard drive and win xp 32 bit on there, figured dual booting would be a little cheaper than buying a seperate pc heh.
    well i have my motors spinning and my axes moving! im just trying to figure out how many steps per mm the axes have.
    since its only going to use a pen im using desk engrave. its a program that lets you type text, in the font you choose, and converts it to g-code. im still kind of trying to find out how it works.
    theres some variables i can fill in but i have no idea what they mean. like: rapid height, plunge rate, dec.places, and increment. feed rate determines the speed of the moving axes, but im not sure at what value thats meant to be set, mm's per second?
  2. #110
    Registered john_100's Avatar
    Mar 2007
    uk
    Hi jorisrf ,
    You have done well to find the software problem with the printer port
    I've no idea how to use desk engrave but if its been writen in the USA
    I expect it to default to inches and not mm
    I'll have to look for the manual for desk engrave to see what it does
    John
    PS
    just found this font :-
    StickFont – Free software for engraving | MachinistBlog.com
    DeskEngrave | MachinistBlog.com
  3. #111
    Nov 2011
    Netherlands
    youre probably right about the inches.
    some useful info on the websites!
    im still hopelessly failing at mach 3, ill try to find some kind of tutorial because i dont even know where to begin at the moment.
    my stepper motors do run very hot, i remember you saying thats normal for steppers, because mine are getting too hot to touch for more than five seconds. just wondering, that might be a little too hot?
    thanks!
  4. #112
    Mar 2007
    uk
    Hi jorisrf ,
    I think I've read some where , stepper motors can run at 80 c !
    to try out Mach 3 ,
    I need to either buy a PCI printer port adaptor card or make a
    cable with a 26 pin connector for my PC mother board , to a 25 pin D-Type
    John
  • #113
    Nov 2011
    Netherlands
    Hi John,
    It's been a while but i finally got round to uploading a video of the little machine
    http://www.youtube.com/watch?v=aXPI4iPEGxw&context=C4968a8aADvjVQa1PpcFO7uNqVrrO24YVFZm8AjwoEaBNsg2Y_sUM=]mini cnc machine out of old floppy drives - YouTube
    Thanks for all the help on the project, have a good one!
    Joris
  • Page 10 of 10 FirstFirst ... 78910
    1. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
      By wf1318 in forum Stepper Motors and Drives
      Last Post: 07-25-2010, 03:19 AM
    2. Is this mill viable for CNC conversion?
      By Ejdepalm in forum General Metal Working Machines
      Last Post: 07-16-2009, 02:44 PM
    3. Has Antek gone to pot? Are they no-longer a viable suppler?
      By JerryFlyGuy in forum General Electronics Discussion
      Last Post: 12-27-2008, 11:55 PM
    4. High Speed Machining viable for DIY??
      By scavenger in forum Open Source CNC Machine Designs
      Last Post: 10-11-2007, 08:46 AM
    5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
      By huios in forum Stepper Motors and Drives
      Last Post: 08-27-2006, 09:43 AM
