Results 1 to 2 of 2
Thread: stepper motor problem
    Oct 2010
    UK
    My stepper motor on my bridgeport boss is not working properally as it stutters and stalls. this happens to which ever motor is pluged in to the x axis board, i have changed the board and get the same problem, so dont know what is happening.
    Dec 2006
    Its posssible the axis is binding at some point.
    Also you might want to check the wiring on that axis, even if it looks good a high resitance connection could cause the problem.
    The signal & wiiring coming from the BOB or computor for that axis would be something else to test.
    Noise getting in to the system that is only close to the X axis wiring. If your running a VFD this is very possible.
    You have changed motors, and driver board so it should be in one of the area's I meantioned. A scope would be good to help pinpoint the problem.
    Jess
    GOD Bless, and prayers for all.
  1. Possible Stepper Motor problem.
    By Michael In Cali in forum DIY CNC Router Table Machines
    Last Post: 09-29-2011, 02:03 AM
  2. Z-axis stepper motor problem
    By techasist in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 07-23-2011, 01:11 PM
  3. stepper motor problem
    By domonic_cnc_guy in forum Stepper Motors and Drives
    Last Post: 12-18-2008, 04:38 AM
  4. Problem with stepper motor stuttering
    By LockTech in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 01-18-2008, 04:44 AM
  5. Stepper motor controller problem
    By Martincho in forum Stepper Motors and Drives
    Last Post: 01-04-2008, 12:32 PM
