My interpretation is that at a gross level the power dissipation calculation depends on the current through the output stage and the "on" resistance of the motor driver, independent of the voltage at which it is being driven, and independent of the heat sink. (The other factors that neilw20 mentioned are presumably operating as well.) Based on that calculation, the heat sink requirements can be estimated from the graphs.
But then I'm not an EE, just an annoying hobbyist, so YMMV...
LinkBack URL
About LinkBacks
