Originally Posted by
doorknob
This is just a guess...
Some steppers that are designed exclusively for unipolar hook-up may not work well using the whole winding in a bipolar hookup.
If that is the case, then you should be able to use half-windings instead of full windings for your bipolar hookup. For example, instead of ignoring the center tap wire from each winding, you could try using one end wire and the center tap wire from one winding as your "A" winding (use electrical tape to insulate the unused other end wire), and do the same thing on your "B" winding.
