Page 18 of 18 FirstFirst ... 815161718
Results 205 to 206 of 206
Thread: Drive a 1.8 degree stepper at 1 RPM
  1. #205
    Oct 2005
    Yeah I checked the project out too. The microstepping is done by the onboard stepper driver chip James. However it only supports 8th stepping.
    Also the coarse timer resolution means there is a limit to how many speeds it can run at, where the Linistepper code I posted for Ceefnas project will do 12th stepping, and uses a very high resolution Bresenham system for timing so it can do practically any speed with great precision.
    And I probably should mention the linear driving of the motor current by the Linistepper means the stepper can move very smoothly (ie "stepless") at a tuned speed. An 8th step chip based driver is going to be a bit gritty for telescope use.
  2. #206
    Aug 2010
    Norway
    Quote Originally Posted by James Newton View Post
    Nice, but the source code on that page seems a bit garbled... I don't see how the microstepping can possibly work as written and there are #includes that don't have files associated, and #defines that are run together on one line.
    Indeed, it's garbled! Haven't noticed, thanks for pointing out! I'm not sitting at the right computer right now, but it will be fixed soon. I'll update. (how strange is that post just above mine here, by nikki66?)
  1. Need Help!- Is a 5056D compatible with a 3.6 degree stepper?
    By Fastest1 in forum Automation Technology Products
    Last Post: 08-16-2011, 05:58 PM
  2. Intermittent pauses at every 1.8 degree for stepper motor
    By fujima4 in forum Stepper Motors and Drives
    Last Post: 03-05-2011, 09:41 AM
  3. linistepper and 0.9 degree stepper motors
    By gasparinho in forum Open Source Controller Boards
    Last Post: 03-18-2009, 01:02 AM
  4. looking for low torque 1.8 Degree stepper anyone want to part with one
    By rkremser in forum Stepper Motors and Drives
    Last Post: 10-11-2007, 03:58 PM
  5. 0.9 degree stepper. Use or not?
    By jdholbrook in forum Stepper Motors and Drives
    Last Post: 05-28-2006, 01:47 AM
