Sounds like more than just that one transistor blew in the driver. Make a table of readings of the voltage at each of the outputs, then single step the driver, and make the same readings again. If there is a difference, it will show up quickly. Generally, it's worth it to replace all the drive transistors as a set.
LinkBack URL
About LinkBacks
