Results 1 to 4 of 4
Thread: Unknown Motor idetentification ?
    Aug 2011
    UK
    My Dad let me have some CNC bits he had knocking about.
    Amongst the bits were 2 screws with steppers attached and a larger stepper with no rating plate.
    with a rating of 11A at 1.5v do I need any special kind of driver ?
    Can I test it with a 5A driver board ?
    How do I go about figuring which wire is which ? There are 6 wires.
    http://i121.photobucket.com/albums/o...K/DSC01939.jpg
    http://i121.photobucket.com/albums/o...K/DSC01954.jpg
    Apr 2004
    minnesota
    Quote Originally Posted by TrickyCNC View Post
    You just need an ohm meter to figure out your motor wires. You can test the motors with less than the rated current, you just won't have the rated torque. I would drop those babies on ebay and replace them with some newer square frame motors. 11amps is a lot of current for 450oz of torque. you can get that with 3amps on the newer motors, and probably still achieve the same speeds you would have gotten with those.
    Aug 2011
    ireland
    Hi there everyone,I recently purchased a cnc machine but had to return it as it was not complete and the replacement machine had noticably smaller stepper motors, they were square in appearance and the first machine had motors that were longer than they were wide. They are supposed to be Nima 23 stepper motors and the dealer tells me now that size makes no difference and that both sizes are 23 motors . Does anyone know if this is the case or am I being mislead.
    Aug 2011
    UK
    I found a link to the spec of my motor.
    550 Oz/In in series mode ?
    spec here MC SUPPLY CO: Bodine Electric Co, KB Electronics, Brake Motor, Stepper, Gearmotor, Gearboxes, Clutch/Brake
    these seem like heavy duty motors, it would be nice to see them working !
  1. How to wire an unknown stepper motor?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 02-05-2011, 07:14 PM
  2. unknown stepper motor wiring
    By vintageracer in forum Stepper Motors and Drives
    Last Post: 02-18-2010, 08:57 AM
  3. Newbie- Unknown Stepper Motor voltage ?
    By Z.K. in forum Stepper Motors and Drives
    Last Post: 11-27-2008, 05:32 PM
  4. Calculating amps for unknown motor
    By Atlas_Too in forum Servo Motors and Drives
    Last Post: 10-06-2007, 11:16 AM
  5. How to determin the operating paramaters on an unknown servo motor.
    By circlecn in forum Servo Motors and Drives
    Last Post: 08-17-2006, 10:36 PM
