Results 1 to 3 of 3
Thread: Increased driver output ???
    Aug 2011
    UK
    So ... My 1st post . I hope it's not a stupid one
    I am just starting to learn about cnc as I want to build my own woodworking router CNC machine.
    I yet have to find the answer "what size motor" , but that I will ask in a different section.
    But, related, is the driver output, and the cost of the driver.
    I have seen 3 axis driver boards quite cheap on ebay. I wondered if it is easy to add an output (amplified) stage between the driver board and the motor, so you can use bigger motors with a feeble driver board. The heavy output driver boards are quite a bit more expensive !, but transistors are cheap
    I am guessing this has been asked and tried several times, so I hope one of you has the answer.
    TIA
    Tricky
    Mar 2003
    Shelby Twp, MI....USA
    The short answer is no.
    Basically, you get what you pay for. There are numerous posts here about the cheap Chinese boards failing, or not working correctly to start with.
    Generally, when building a CNC, do your research before spending any money. Most people that try to save money end up spending more money, because they end up buying the cheap stuff first, then upgrading to what they should have bought in the first place.
    Aug 2011
    UK
    Thank you.
    I half guessed as much when I couldn't find the answer !
  1. Building for Increased Machine Accuracy
    By CanAm1 in forum Zen Toolworks Machines
    Last Post: 01-15-2011, 12:37 PM
  2. Newbie- Amplifying Driver Output
    By Dman65 in forum General Electronics Discussion
    Last Post: 07-30-2009, 07:00 PM
  3. Increased tool life
    By CNCROOCKIE in forum Product and Manufacturer Announcements
    Last Post: 05-27-2009, 12:22 PM
  4. Increased ipm
    By ecope in forum Taig Mills & Lathes
    Last Post: 01-12-2009, 11:29 PM
  5. 8830 Line driver for encoder output?
    By murphy625 in forum CamSoft Products
    Last Post: 03-29-2005, 02:15 PM
