Results 1 to 5 of 5
Thread: micro step or f-h step ic ??
    Feb 2011
    egypt
    hi i want to make pcb machine so i am confused to
    select ics for the driver for more accuracy. what is better for pcb machine ic for microstep
    or ic for half and full step ?????
    Jan 2005
    Toronto, Canada
    tba6560.
    Feb 2011
    egypt
    thx for u answer but i dont understand u
    which is perfect for pcb micro step or harlf and full step??
    Jan 2005
    Toronto, Canada
    Microstep is better. Half step or full step will cause the motor to vibrate too much. The tb6560 is a microstepping chip. You can buy a 4 axis tb6560 board for $50. But you will need to make changes to it before it will work properly.
    Feb 2011
    egypt
    THX FOR U REPLAY if u test it before plz can u help me to know more about driver and who to make it ?
    1. My 20A bipolar micro-step driver design
      By nerginer in forum Stepper Motors and Drives
      Last Post: 08-29-2010, 02:33 PM
    2. Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor
      By Calico in forum DIY CNC Router Table Machines
      Last Post: 04-09-2010, 08:23 PM
    3. Need Help!- Step/Direction pins should be Step FWD and Step BACK
      By rayscott in forum Mach Software (ArtSoft software)
      Last Post: 02-09-2010, 06:57 PM
    4. g540 any way to not micro step x10
      By chrisw765 in forum Gecko Drives
      Last Post: 05-25-2009, 11:46 AM
    5. NEW! 4D H2 PCB CNC Controller (Micro-Step)!
      By icm in forum Product and Manufacturer Announcements
      Last Post: 04-22-2009, 11:55 AM
