View Poll Results: Which driver?
Voters
7. You may not vote on this poll
  • Mechatronics board from easycnc
    1 14.29%
  • Hobby Cnc chopper board
    5 71.43%
  • FET-3 from stepperworld
    0 0%
  • TA8435 from cncgeeker
    2 28.57%
Multiple Choice Poll.
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Stepper/Driver Advice (I'm new, but have done some research.)
  1. #13
    Registered James Newton's Avatar
    May 2005
    It's a bit late I guess, but I'd like to suggest the linistepper:
    linistepper.com as a low cost alternative for students and hobby builders. It's unipolar, can manage up to 2 amps (3 amps max with CPU fans) at 35 volts and it costs $30 each in sets of 3 or more as a kit you assemble. Pretty easy to put together, but more importantly, it's very forgiving and cheap / easy to repair if you fry a driver. And... It's totally open source.
    Good luck!
  2. #14
    Jan 2005
    Toronto, Canada
    Quote Originally Posted by AssassinXCV View Post
    The only difference between 24 volt power supply and 36 volt power supply is that the motors will run faster with the 36volts.
    Correct. Double the voltage and you double your speed.
    But also, aren't the motors only rated for like 4volts? so why is the voltage so high??
    Inductance. The current does not have enough time to reach 3 amps before the next step pulse arrives unless you have higher electrical pressure to force it through.
    Everything else you said was correct.
  1. Newbie advice request on stepper/driver sizing
    By K. Browne in forum Want To Buy...Need help!
    Last Post: 07-07-2011, 02:48 AM
  2. Need Help!- 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors and Drives
    Last Post: 07-25-2010, 03:19 AM
  3. Replies: 2
    Last Post: 08-19-2008, 09:44 AM
  4. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors and Drives
    Last Post: 08-27-2006, 09:43 AM
  5. Newbie needs stepper driver advice
    By deferr in forum Stepper Motors and Drives
    Last Post: 08-07-2006, 10:45 PM
