Sounds like resonance. What drives are you using? What microstepping?the one thing i have noticed is i can get higher speeds and less jerking from the motor if i hold it really tight as to not allow any lost energy in the motor to be used to twist it
LinkBack URL
About LinkBacks
) the one thing i have noticed is i can get higher speeds and less jerking from the motor if i hold it really tight as to not allow any lost energy in the motor to be used to twist it. I have a friend with a mill that i could test my stuff with but that would tell me nothing since it would be a different computer, different settings, different driver and a different power supply. that's too many variables to get any conclusive answer and he wouldn't have the patience to test one at a time(neither would I). My guess is the extremely low voltage is not allowing the coils to lose/build their charge fast enough causing random jerks and lost steps(that was something i just thought of and has absolutely no reason behind it besides the fact that it sounds possible but it's what i'm going with/hoping.
) The only way i've been able to successfully keep all the steps it by going at a speed that is essentially one step at a time. If anyone has any clue why this may be happening please help.
I just took a piece of wood about 1"x4"x.75" and drilled a slightly smaller than .25" hole in the center(must be centered!!) and just pushed it onto the shaft. On half step mode before damper i could get 40ipm(400rpm) and with the damper i got up to 180ipm(1800rpm). On single step mode before damper i got 25imp(250rpm) and after I got 300ipm!!!(3000rpm), that's a 1100% increase, a piece of wood!!! That's on 12volts too so when i get it running at 35v i should have all the power i need at 60ipm. Still have really bad resonance at 6ipm on single step so i have to accelerate fast to avoid losing steps(but i'm not going to use single step so it doesn't matter much). One problem though, my motors are all single shaft so for the tests i put the damper on the main shaft. Is there any way to extend the shaft? I could make a funky looking motor mount that would allow the damper to be in the front but that'd be a last resort. I'm looking to get new motors around 260 oz-in (mine are 160 right now) but those also don't have dual shafts. does anyone know where i can get steppers with dual shafts besides the 425oz-in ones on ebay which are expensive/overkill/will not help max cutting speed. P.S.-my machine is going to have a cutting area of 15"x15"x4" and it's going to be all aluminum(besides the spoil board) and the gantry will weigh around 60lbs(it's gonna be a beast made for cutting aluminum). do you guys think with these motor sizes i can get 60ipm in aluminum with a linear cutting force of around 10lbs. Thank You
