Results 1 to 2 of 2
Thread: Calculation Check
    May 2011
    Calculation Check
    Hi, I am a newbie, but I have done an enormous amount of reading on stepper motors recently.
    Unable to resist the urge, I bought 3 small cheap stepper motors on ebay in order to convert my little proxxon mill.
    The motors had no specs, so I sent an email to the manufacturers requesting specs and was told the motors were custom made and so they could not release the specs. I asked if there was anyway they could give me some information so I don't destroy the motors without giving anything proprietary away. I received the following one line email:
    'Do not exceed 4 watts for the input'
    The motors are Nema17, and I have determined that they are bipolar motors.
    When I connect my multi-meter across any of the two coils I read 9.6 ohms
    I am assuming then that using P = I squared R that the max amp rating of these motors is:
    4 = I squared x 9.6
    = sqrt(4/9.6)
    = 0.65 A/coil
    Does this seem correct, or am I misinterpreting the information?
    Thanks for any guidance
    Oct 2005
    4 watts per phase sounds a little hot for size 17 motors, but is probably ok if you are running a microstepping drive (not a full step drive).
    Your calculation looks good.
    Bear in mind the max dissipation of 4W will be with the motors mounted to a reasonable thickness of aluminium plate. You might need to de-rate the power a little bit if you have the motors mounted on something that is not a heatsink.
  1. NC- Calculation, help please :)
    By Snajder in forum Mechanical Calculations/Engineering Design
    Last Post: 04-23-2010, 12:11 AM
  2. Transformer calculation
    By CNCDevil in forum General Electronics Discussion
    Last Post: 08-18-2009, 09:51 PM
  3. Need Help!- calculation
    By biotec in forum Stepper Motors and Drives
    Last Post: 04-20-2009, 02:26 AM
  4. Replies: 3
    Last Post: 01-19-2007, 08:59 AM
  5. Back EMF calculation?
    By OCNC in forum Stepper Motors and Drives
    Last Post: 12-08-2004, 11:03 AM
