Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-03-2011, 11:31 AM
cablood is on a distinguished road
Stepper whirrs under no or little load
I am running stepper motors from the KL-8056D unit with the KL- 6520 power supply controlled through a C35 - QUICK SETUP BREAKOUT BOARD running off of a SmoothStepper USB Motion Control Interface for Mach 3 running Mach3 software.
When the motor (1350oz) has a load on it, it runs fine, BUT with out a load on the motor it will not. Sometimes it turns and sometimes it freezes (whirrs). It cannot be tuned, it does this at all settings. Even with a light load I have this issue.
I have also tried a 820oz motor and it does the same thing.
This motor is turning a 60 inch ACME screw horizontally with a 40 lb load on the screw and fails to turn as described above.
It works fine with a set up where it turns two 60 inch screws with a 140lb load
Do you have any idea what is going on with this issue?
Old 03-03-2011, 12:21 PM
The proper term is STALLS not whirrs. Sorry.
Old 03-04-2011, 06:09 AM
vger's Avatar
vger is on a distinguished road
What pitch is your acme? How fast are you trying to run? What settings have you tried in Mach3?
Steve
Old 03-04-2011, 01:20 PM
James Newton's Avatar
James Newton is on a distinguished road
Classic resonance problem. Add a damper or try a higher microstepping mode.
Old 03-06-2011, 10:47 PM
The ACME is 5 per in. I'm trying to run 200 in/min.
I tried to run full step through 16 micro step with the same effect.
Mach 3 is set to 35khz
Tuning set to:
3ms pulse
12 ramp up
8000 pp
200 in/min
And I have tried a number of other settings
Add a damper? how? what?
Old 03-07-2011, 07:02 AM
vger's Avatar
cablood,
There are different types of dampers. Some have a hub surrounded by a ring that is elasticly coupled to the hub. A steppers rotary motion on each step will overshoot due to the intertia of the rotor and attached rotating mass (screw) and "ring" back and forth a little bit at the systems naturally resonant frequency. At some critical frequency (step rate) the ringing builds to a point that a subsequent step actually steps the wrong direction and additional steps then step back and forth in a stalled condition.
One person on the forum found that a hocky puck attached to the shaft cured his problem. Another uses a disk assembly that has several holes near the edge into which are small rollers with cover plates to contain the little rollers. Another used screws extending radially from a hub with loose washers on the screws (a bit noisy I think).
Steve
Old 03-07-2011, 05:00 PM
I think I'll try the disk device with ballbearings in pockets and see if that works at all.
Do you know if the GECKO controlers resolve this issue?
[IMG] code is Off
Need Help!- Stepper Whirrs without load cablood Machine Problems, Solutions , Wireless DNC, serial port 1 03-03-2011 12:22 PM
Problem using stepper for high-momentum load... (blowing drivers!) Riceburner98 Stepper Motors and Drives 10 09-17-2008 12:29 PM
Z load on vf-3 mls Haas Mills 5 05-15-2008 10:54 PM
Stepper Motor Belt Drive Side Load Question harryn Stepper Motors and Drives 3 08-07-2007 05:23 PM
stepper motor load resistor and figuring out phases? drtuto General Electronics Discussion 7 03-19-2005 02:53 PM
