Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-03-2011, 09:09 AM
rb765 is on a distinguished road
Printer Steppers
In my quest for a small mill out of recycled parts, I obtained a laser Fax for it's motors. The first looked fine like a standard 4 wire stepper motor but with only a 2 hole mount. The second looked like a large brushless motor. When turned, it also feels like a brushless, not a stepper. Is this second motor usable for a small CNC project, or do I need to keep scrounging?
Old 03-03-2011, 04:34 PM
TCarey is on a distinguished road
Probably need to keep looking.
I'm also building a scrounged parts mill for PCB's.
I have decided to use 5 1/4 " floppy drives for both the motors and the control electronics. 5 1/4 " floppy drives have NEMA 17 sized motors and the existing electronics board is set up to accept step and direction signals. And as an added bonus, uses standard computer power supplies.
That solves a lot of issues in fell swoop.
Now on to the problems of tables and bearings etc.
Tom
Old 03-03-2011, 06:15 PM
Steppers
Thanks for that info. I think I have access to a few of them.
Old 03-04-2011, 01:26 PM
James Newton's Avatar
James Newton is on a distinguished road
Certain laser printers and copiers are excellent sources of even larger stepper motors. There is a list at:
techref.massmind.org/techref/io/stepper/linistep/motors.htm which you may find useful.
Also:
cnczone.com/forums/showthread.php?p=136761 HP LaserJet II stepper motors.
cnczone.com/forums/showthread.php?t=19362 Raiders of the Lost Photocopiers
Old 03-04-2011, 10:10 PM
Steppers
Thanks for that info. I will be scrapping a few more printers in the next few days for my job. They didn't say they had to be complete when they made it to the trash. Hopefully I will be able to start on my machine build this weekend, so I will be able to take all this theory stuff and put it into action. Wish me luck.
Old 03-04-2011, 10:18 PM
Let us know what you find!? Printer model and stepper model.
Old 03-04-2011, 10:42 PM
Printer
The one I tore apart was a Brother Intellifax 2820. There were only two motors in the thing, one was a large brushless motor, and the other was a small bi-polar stepper with 4 wires. The only numbers on it were 039213 with no brand or other specs. I will be tearing apart a HP inkjet and an Apollo inkjet. I also will be scrapping several 9v battery chargers that charge about a dozen batteries at a time, and an old dictophone power supply with outputs for 12v, 5v, and -5v. I believe it only puts out 2amps total, so it may not be of use for a mill, but might have some nice parts to use elsewhere.
[IMG] code is Off
Specs For Genicom Printer Steppers BEARINGMAN Benchtop Machines 4 01-20-2009 09:54 PM
Xerox Laser Printer use steppers ? ringram2077 Stepper Motors and Drives 0 05-26-2007 08:57 AM
Printer steppers dead, looking at replacements from Digikey ipodman1991 DIY-CNC Router Table Machines 15 01-21-2007 08:53 PM
Old laser printer steppers hma DIY-CNC Router Table Machines 3 02-16-2006 06:20 PM
Using Printer steppers Rance DIY-CNC Router Table Machines 0 09-10-2005 06:06 PM
