Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 03-01-2011, 01:20 PM
Pyro2 is on a distinguished road
Any one know about Soc Robotics drivers
Hi, I'm new to cnc, I'm about half way into my cnc build. I bought a 4 axis soc robotics MK4
http://www.soc-machines.com/pdfs/MK4...e%20Manual.pdf
and 3 MM160 http://soc-robotics.com/pdfs/MM160%2...al%20Brief.pdf
I see that I can set up limit switches, but can I set up home switches on this driver board? Any input would be welcome.
Thanks,
Chet
Old 03-01-2011, 06:22 PM
jschmitt is on a distinguished road
Your URLs doesn't work. I looked at this: http://www.soc-machines.com/pdfs/MK4...e%20Manual.pdf
If this is it then yes there are pin connectors to the left of the parallel connector.
Old 03-01-2011, 07:02 PM
I fixed the links now, thank you.
@jschmitt yes that is the board.
sorry I am very new to cnc, are you talking about the white header next to the parallel port and how would I wire it? If it is the white header then I can still use the limit switch header for the limit switches.
Thanks again,
Chet
Old 03-02-2011, 06:31 PM
Thanks again,
Chet
MY other left side
there are 5 set of 2 pin connectors on the RIGHT side of the parallel port connector that are for limits and estops.
the white header is for reprogramming the cpld chips.
Use one of your limits as a home. If you don't want to home on the edge of your travel you can set emc or mach to make a soft limit so you can travel to your limit and the machine will stop automatically, when it reaches the limit.
Old 03-03-2011, 01:50 PM
Thank you, I'll have to play with that.
[IMG] code is Off
powermax robotics/cnc interface stirling Hypertherm Plasma 40 03-28-2012 01:51 PM
rhino robotics lathe.. gadget47 Mach Lathe 4 03-15-2012 06:54 PM
Problem- RHINO ROBOTICS ST/7 CNC LATHE airamp Benchtop Machines 11 09-30-2011 09:46 PM
US First Robotics cidteach CNCzone Club House 0 10-10-2007 10:54 AM
Adept Robotics System..not sure what to do with it drewgarth Servo Motors and Drives 0 07-11-2006 07:22 AM
