Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-19-2011, 09:23 PM
sndpntlynch is on a distinguished road
Need help with motor direction
I'm in the process of building my own router table. I am using two rack-n-pinion drives for my Y Axis. I have two separate motors for this. without having to place one rack on top or pinion and one on the bottom to make motors travel in same direction. Can I revers polarity in the motor so the will turn in opposite direction and place them both on top of the rack. Or can I reverse the direction in my cam program.
Old 02-19-2011, 10:04 PM
george4657 is on a distinguished road
Changing direction with a stepper is as simple as changing the wires around or making a change in the software. Design your system with the assumption the motors can turn in the same or opposite direction as required.
George.
Old 02-20-2011, 06:36 PM
help with motors
Thank you for your reply. I thought I could do this but was not sure.
Old 02-20-2011, 08:10 PM
keebler303 is on a distinguished road
To clarify, your steppers have 2 phases. You need to reverse the polarity of one of them. The details of which wires to swap depend on your motors, 4, 6 or 8 wire.
Matt
[IMG] code is Off
My UHU Controller Run Motor In One Direction Only !!! AbuTarif UHU Servo Controllers 1 07-20-2011 11:16 PM
Need help with motor direction marzetti Automation Technology Products 5 11-30-2009 08:59 PM
Motor Direction Ken Bond Phase Converters and VFD 2 11-20-2007 06:22 AM
Motor only moves one direction spoiledbrat Mach Software (ArtSoft software) 3 06-12-2005 01:02 PM
motor direction sixpence Mach Software (ArtSoft software) 2 12-28-2004 10:15 PM
