Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-11-2011, 09:08 AM
grumpygeek is on a distinguished road
Question Lin Engineering 5718L-12E-01 Bipolar stepper motor
I found these motors on the alltronics site: Lin Engineering - 5718L-12E-01 Bipolar stepper motor and bought a couple thinking I could use them with one of various A3977 boards I own (Xylotex, Probotix, and Rockcliff), however now I am not sure. The spec sheet can be found here: http://www.alltronics.com/mas_assets/acrobat/28M069.pdf. I have a basic understanding of how steppers work, and how to wire them, what I am lacking is how to go about figuring out the electrical requirements for a given motor. I think I can drive the motor listed as bipolar parallel up to 2.8A , but I am not sure and would like to know how to figuring it out since it would make buying surplus stuff a lot easier .
I did read in some document on the Lin Engineering site that the voltage did not matter as long as the Amp limit was followed.
Here is some additional documentation: wiring diagram (pdf) and product detail page.
I have done a bunch of goggle searches but have not found anything useful. Any help figuring out the how to set these up would be greatly appreciated.
Thanks,
GrumpyGeek
Old 02-12-2011, 08:53 AM
OK, I did some more searching this morning and found a couple of documents that helped me figure out the motors:
Lin Engineering Standard part numbering system
Lin Engineering Stepper Motor FAQ
And this is the best stepper motor tutorial I have come across so far:
How Stepper Motors Work
So my original guess that I could run these up to 2.8A seems correct (2A x 1.414 for using the micro-stepping board with bipolar parallel wiring). The driver maxes @ 2.5 so I shouldn't be able to screw it up, if you think I am in error please let me know before I let the magic smoke out .
Thanks again,
GrumpyGeek
Tags
motor voltage, stepper driver, stepper motor
[IMG] code is Off
Need Help!- 5718L-03P Stepper Motors eqalizr Stepper Motors and Drives 4 09-04-2010 09:48 AM
Bipolar Stepper Motor (Epson) shreifali Stepper Motors and Drives 9 01-27-2008 05:52 PM
Bipolar Stepper Motor Power Supply mdframe Stepper Motors and Drives 13 01-27-2006 11:50 AM
RQ: Bipolar stepper motor driver circuit elektronchika Stepper Motors and Drives 2 12-21-2005 05:29 PM
Just receaved my bipolar Stepper motor Marc Stepper Motors and Drives 2 05-13-2005 07:38 AM
