Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 02-07-2011, 04:55 PM
kmist is on a distinguished road
6 wire stepper
Hello all I'm new to forum, just wanted to see if anyone has wired a six wire stepper? I have the wires separated into two groups that have continuity a I have found the center tap. The question is what do I do with the center tap is it a ground? and how do I determine witch is A+ A- B+ B- ?
I thank it is as folowes
A+ red
A- blue
com white
B+ black
B- Green
com yellow
Old 02-07-2011, 05:32 PM
packrat is on a distinguished road
A+ red
A- blue
com white
B+ black
B- Green
com yellow
If your wiring it as a UNIPOLAR both center taps are connected to the motor supply positive.
If wiring as a BIPOLAR the center taps are not used at all. Just tape or heat shrink tubing the end of the wire.
Old 02-07-2011, 06:05 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
The motors should have more torque wired bipolar.
Jim
Old 02-07-2011, 06:40 PM
Thanks just refitted an old AXYZ router and started on my own but when stepper come they had 6 wires not 4. dose it matter witch set is on A or B and dose it matter witch is - or + ?
What is the speed def from bipolar and unipolar ?
Old 02-08-2011, 06:01 PM
There is no speed difference between the two types. Speed come from the controller inputs. A bipolar will usually have more torque than a unipolar.
You have no way of running unipolar, since you have a bipolar controller. Theres no way to know which is the right way to hook up the wires. Just hook them up and if it moves the wrong direction switch one of the pairs. read this for more information;
Jones on Stepping Motors
Old 02-08-2011, 07:33 PM
Thanks for the help !
[IMG] code is Off
Running stepper motor wire with router wire? basskitcase DIY-CNC Router Table Machines 2 02-19-2010 10:18 AM
How to wire an 8 wire stepper motor technosteve DIY-CNC Router Table Machines 1 01-16-2009 05:01 PM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
help help stepper ?8 wire jarr88 Stepper Motors and Drives 2 04-24-2006 09:26 PM
12 wire stepper extreme Stepper Motors and Drives 5 03-24-2005 05:56 PM
