Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-26-2011, 06:42 PM
flint1962 is on a distinguished road
Unusual steppers
Do these steppers have an integrated controller board or what would the board be for. These are out of a laser printer Phaser 740
Old 01-29-2011, 08:29 AM
vger's Avatar
vger is on a distinguished road
what steppers? picture?
Old 01-29-2011, 04:37 PM
I did have pics posted but was deleting the thread as I was getting no response. Thank you for your response. Here are the pics
ID:	125145   Click image for larger version
ID:	125146   Click image for larger version
Old 01-29-2011, 11:06 PM
johnmac's Avatar
johnmac is on a distinguished road
It looks like a driver. The only problem is laser printers only feed in one direction. I don't see any way to change direction.
John
Old 01-30-2011, 02:50 AM
xatxtal's Avatar
xatxtal is on a distinguished road
Stepper Driver and Motor
Hello Flint.
First the photos are good, makes it so much easier to study.
Second I do not know this item and a google search comes up with nothing.
However the board has a lot of information , the connector and motor are marked 24v so 24 volts for the motor drivers, the size of the heat sink and driver transistors would suggest 10 t0 20 watt motor, If you are able to read the winding resistance we could come up with a better figure.
Next 5v would indicate 5 volts for the other components.
The CLK input would indicate a external clock pulse to regulate the step rate, possoble NE555 timer for a clock.
The S is possible step (one pulse one step)
LD possible is direction.
P/S I have know idea but possible hold current or enable board.
OK none of this is certain, but if it was mine I would hook it up to 24volt and 5 volts, and play with the other inputs by grounding them out( most inputs tend to float high so grounding them changes the state.
As for the clock if you do not have something to create it connect CLK to S and tap the connection to ground, you may be rewarded with a single step of the motor.
What have you to lose.
That is if no one else can come up with any thing better.
Good luck
Trev
Old 01-30-2011, 03:52 AM
awemawson is on a distinguished road
Beware - it's just possible that the 'S' next to the 5v is a 5v sense wire running back to logic power supply. Easy to check by looking at the pcb traces - if it's directly connected to the +5v or by a lowish value resistor then it's a sense wire.
Andrew Mawson
East Sussex, UK
Old 01-30-2011, 06:44 AM
Thank you for all your replies. At least I have a place to start from.
Old 01-30-2011, 06:47 AM
vger's Avatar
Flint,
Looking at the board, I am seeing 3 large traces going to the motor with 3 diodes connecting from those traces to another trace. This would indicate to me that the motor may be a three phase brushless (BLDC) motor rather than a stepper. How many detents are there as you rotate the motor shaft? If there are just 12 springy detents per revolution, then it is most likely a BLDC motor similar to the ones used to spin hard drive disks, only a little larger.
Steve
Old 01-30-2011, 09:36 AM
xatxtal's Avatar
Good observations
Very good,
yes the S could be sense, and the thoughts on the heavy tracks do look more like a three phase.
Looking more close at the photos there seems only 3 transistors and three diodes, if this is confirmed by flint then vger may have cracked it.
What a clever bunch of folk this forum has. Many thanks.
And I have learned some more.
Trev.
Old 01-30-2011, 01:06 PM
Thanks so much everyone.
There are 24 detents in the motor. Also the large chip on the front of the board with the heatsink is a SLA6012 three phase motor driver.
[IMG] code is Off
Unusual Red Drill Press Louie's Girl CNCzone Club House 2 03-03-2010 07:06 AM
ID for unusual cnc tool holder? paulx General Metal Working Machines 7 08-07-2009 10:09 PM
Unusual noise from my mill studysession General Metal Working Machines 2 03-24-2007 07:42 AM
Favorite place to buy unusual fasteners? InspirationTool Mechanical Calculations/Engineering Design 2 06-09-2006 06:49 AM
