Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-26-2011, 01:30 AM
CNCpatriot is on a distinguished road
microstepping pros&Cons ..
Iam building a DIY CNC router using stepper motors.
1) My first doubt is whether to microstep or to halfstep or full-step.
I have a micro-stepping drive. But not sure about the pros&cons of microstepping vs FullStepping.
Is microstepping really reliable in terms of positioning accuracy, particularly when there is router load?
2) My stepper drive has option of lowering the current to half , when it is not receiving pulses i.e. idle.
Should I use this feature or not? This feature is ON by default. But say Iam cutting a rectangle, when Iam doing X-move, Y-axis will be idle and so will be at half the torque. Is this advisable?
regards
Old 01-26-2011, 11:12 PM
James Newton's Avatar
James Newton is on a distinguished road
1. Try all three. Microstepping can help get through mid band resonance and so may help you achieve your systems best speed. The positioning isn't any worse than full or half step... it may not be better. Typically, microstepping introduces more heat in a motor (if your driver is a chopper) and more heat in the driver (if it is a linear driver e.g. Linistepper).
2. Doesn't that typically happen after a few seconds of idle? It would only be an issue on really slow cuts on really large runs. Keep a couple of cheap digital thermometers on your motors and drivers while you test the system and if the temperature is getting out of hand between runs, turn on the idle reduction.
Tags
microstep, stepper drive, stepper motor
[IMG] code is Off
Pros and Cons SB2C-1 Surfcam 3 12-13-2010 04:48 PM
Pros and Cons of X4, CNC Jr... timberwolf5480 Benchtop Machines 19 04-15-2009 10:46 PM
pros and cons stirling Stepper Motors and Drives 9 08-28-2007 09:40 AM
Pros and Cons of Two Designs PaulH DIY-CNC Router Table Machines 9 10-22-2005 09:22 AM
What are the pros and cons of CNCadmin CNC Machining Centers 1 05-19-2003 12:31 AM
