Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-24-2011, 05:16 PM
SIMONSIGNS is on a distinguished road
Nine pin encoders please...
why doesn't someone make an encoder with a simple 9 pin D socket instead of those tiny US Digital crappy connectors.
I'm sure it could be the decoder of choice with easy to obtain wires and connectors and good solid reliability?
Is there a reason its not already been done
South London Signs | Sign Makers Beckenham |Signs Bromley | Signs Croydon | Signs Beckenham | Shop Signs | Window Graphics | Banners. We cover Croydon & Bromley, Penge & Lewisham, Sydenham & Crystal Palace
Old 01-24-2011, 05:24 PM
Al_The_Man's Avatar
They do it because its cheap, traditionally encoders have had more rugged termination/connectors from sealed hardwired cable to MS (military style) connectors.
US digital are an the bottom end of the encoder scale, price wise.
'D' connectors were not really intended for this kind of industrial application, just that they are also a cheap but not industrially rugged.
Old 01-24-2011, 05:43 PM
Hi Al The Man.
9 pin D connectors would be far stronger than those connectors on the E5S range from US digital. I don't think they could make them much weaker and prone to fault. Maybe its just me?..
If I knew where I could get some good quality heavy duty encoders to replace my E5s's. I'd be first in the que and have much lower blood pressure.
Old 01-26-2011, 11:56 AM
ChipsNChips is on a distinguished road
Connectors can be changed, just like bolts and nuts. If you want to use the DE-9 style connector, they are available with crimp-on pins so no soldering is needed. Do get a proper crimp tool, not a $20 cheepie. Look for a tool with a ratchet to insure the crimp is fully made.
Look at Digi-Key or Mouser.
Digi-Key
Mouser Electronics - Electronic Component Distributor
or any other good electronic supply. While you are there, you can look at other connector styles that are far better than the "D" series.
[IMG] code is Off
cheap absolute encoders? Oxymoron? Decent Incremental encoders? mattbesquare Benchtop Machines 15 09-08-2010 06:56 PM
Encoders seb fontan General Electronics Discussion 1 09-27-2005 03:28 PM
Encoders? chas Servo Drives 11 04-13-2005 12:49 PM
Encoders-to be-or not to be George Stepper Motors and Drives 2 02-16-2005 02:08 PM
