Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-20-2011, 06:13 PM
geekinesis is on a distinguished road
confused about stepper motor options
Hi there
I am adding new stepper motors to a laser cutter and have a 3.5 amp control board.
If I run 12v 0.4 amp steppers at 24 volts does that mean that they will be pulling 0.8 amp of current?
I am looking at 2.8v 1.6 amp steppers, but I am assuming if I run them at 12v the resulting current will be too much for the board I have?
3 Axis Stepper CNC Motor Driver Board Controller TB6560
If anyone can recommend the best motors to use in this board running at 24v or 12v I would be grateful. It is a laser cutter so the torque is reasonably low. I am looking at nema 17 size motors ideally but all the different options for these motors are confusing me
rabbit / ls3040
[IMG] code is Off
Lathe Variable Spindle motor options? VFD? Servo? Stepper? DC? whiteriver General Electronics Discussion 21 03-16-2011 07:38 PM
New Machine Build- 12X12in vmc build confused about servo or stepper jasminder Vertical Mill, Lathe Project Log 8 12-17-2010 02:53 PM
5 axis TA8435 stepper driver board-confused tiffyted Stepper Motors and Drives 16 09-17-2010 06:36 PM
Confused about arceurotrade stepper specs posix Stepper Motors and Drives 3 09-27-2009 07:52 AM
what voltage? i'm confused.. Stepper motors + driver board from hobbycnc Loterus Hobbycnc (Products) 8 01-26-2005 07:10 AM
