Results 1 to 6 of 6
Thread: Vexta 5 Phase Motor Driver Question
    Dec 2004
    Hi there.. I have a UDx5114N (Vexta 5 phase 1.4amp driver) and PK569auha 2.8 amp stepper motor. I was curious to find out if it will be a problem to drive the motor with this driver. I imagine I won't get the full potential out of the motor, but I am okay with that. Just wondering what and if damage may happen as a result. Any input would be really appreciated..
    Thanks everyone..
    Jan 2011
    Interesting to find this question posed, because I was just about to ask about 5-phase steppers myself. I just got two Oriental Motor .72 deg/step 5-phase stepping motors and I'm trying to figure out how to drive them. They have 5 wires. If I knew the stepping sequence, making a driver with a microcontroller shouldn't be too bad but it would take 10 discrete transistors because nobody makes 10-transistor darlington arrays.
    May 2011
    Germany
    hi powerfade,
    by chance I found your inquiry. Therefore maybe late response.
    Basically it will work well - no risk at all. Disadvantage: The available torque will be 50% (half current means half torque) at low speed. In case of higher speed the difference will be less. Soon or later (depending on power supply) you'll have nearly same torque.
    Registered vger's Avatar
    Jan 2006
    You might try this driver....
    Item # DS514-2, On-Board Type New Pentagon (Bipolar) Full/Half-step Driver (12 - 24 VDC) on Oriental Motor U.S.A. Corp.
    They also have other drivers for 5 phase motors.
    Registered john_100's Avatar
    Mar 2007
    uk
    Hi BetterSense ,
    is this link any help with the 5 phase sequence :--
    http://www.orientalmotor.com/technol...verOptions.pdf
    John
    Jun 2011
    Vexta 5 Phase Steppers
    Quote Originally Posted by BetterSense View Post
    What type of steppers do you have? I have Vexta 5 phase PK564AUA 1.4A that I am looking for the best drivers to use. Just wondering what you came up with and if you have any advise.
    1. Vexta 5-phase stepping motor
      By landart in forum Stepper Motors and Drives
      Last Post: 01-29-2011, 02:18 PM
    2. THK Actuators & Vexta Stepping Motor With Driver
      By Maplelite in forum EBAY ADS
      Last Post: 01-02-2010, 10:36 AM
    3. Newbie- Vexta stepper motor Question
      By Navop in forum Stepper Motors and Drives
      Last Post: 08-25-2009, 12:06 PM
    4. vexta stepper motor and electronic utopia driver
      By DanOSB in forum Stepper Motors and Drives
      Last Post: 10-10-2005, 08:13 AM
