Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-17-2011, 07:40 AM
CNCpatriot is on a distinguished road
24V from SMPS power supply ...
Hi ,
Iam trying to build a DIY CNC router.
Iam using stepper motors, whose drivers need 24V power supply & controller needs 5V supply.
Iam wondering whether I can connect 2 SMPS supply from standard PC in series and get my 24V for the stepper drivers.
PC powersupplies are very cheap, and give enough amps needed for steppers, but give only 5V & 12V.
Looks like the COM of SMPS voltage is connected to the chasis.
Iam thinking of isolating the COM from the SMPS chasis and using 2 SMPS in series.
Have any one tried this?
regards
Old 01-18-2011, 02:28 AM
xatxtal's Avatar
xatxtal is on a distinguished road
PC power supplies.
The quick answer is yes, the following link will tell you how.
ProCooling.com
I have tried it and very satisfied.
Trevor
Old 01-18-2011, 02:35 AM
why resisitor across 5V?
Any idea why resistors are to be connected across the 5V? ( as suggested in the procooling site)
I was planning to use the 5V to power my controllers. So dont understand why he has suggested to connect lowOhmHighWatt resistors across the 5V.
regards
Old 01-18-2011, 08:17 AM
doorknob's Avatar
doorknob is on a distinguished road
This is just a guess, but apparently some PC power supplies will not produce any output unless they sense a sufficient load current on the 5 volt rail.
So the resistors may be providing such a load to ensure that the power supplies function properly.
Old 01-18-2011, 10:57 AM
xatxtal's Avatar
Load resistor
Switch mode power supply's normally need a load to work, as PC power supply's normally supply 10s of amps so the little current used by your driver boards would not be enough to kick start the power supply.
You can still use the 5v supply.
The following link may help as a resistor is built in and it shows the other lines are good.
PC Power Supply Tester 20/24 Pin PSU ATX SATA HDD on eBay (end time 09-Feb-11 07:44:37 GMT)
Or do a search on Ebay for "PC power tester"
they are so cheap from Hong Kong it is worth having.
Trev
Tags
24v, dc power supply, smps
[IMG] code is Off
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 05:13 AM
controller power supply 115/230v OK for Australian power? Momill Australia, New Zealand Club house 8 07-07-2011 11:06 AM
Need Help!- SMPS power supply ... CNCpatriot DIY-CNC Router Table Machines 8 01-18-2011 07:29 AM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 07:03 PM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
