Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-07-2011, 09:08 PM
eaglezsoar's Avatar
Gold Member
eaglezsoar is on a distinguished road
What stepper to use?
I have a 24 Volt power supply and a driver board from Hubbard CNC that is bipolar and operates up to 36 Volts and 3.5A max per axis.
This is the link to the driver if you are interested: CNC 3 axis Stepper motor Driver TB6560 INCLUDES EXTRAS - eBay (item 330424320309 end time Jan-10-11 08:27:09 PST)
I have an X2 mini-mill that I would like to convert to CNC. I know the formulas to determine stepper voltages etc, but I am looking for a stepper motor that can run on the above 24 volts driver and supply and have enough oomph to
work with the X2 conversion. Can anyone recommend a Kelinginc stepper that could be used in the 24V scenario?
Regards, Carl
[IMG] code is Off
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
15" Color LCD Monitor W/USB Port HelicopterJohn Haas Mills 3 11-01-2007 12:12 PM
stepper motor color coding MacControls Stepper Motors and Drives 1 02-23-2007 03:12 PM
Typical color code of stepper motors abasir Stepper Motors and Drives 0 05-29-2005 09:19 PM
