Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-07-2011, 11:08 AM
derkiow is on a distinguished road
driver power supply
I have a 68volt rectified output that needs a bus capacitor of 7200uf , 91volt and 5amp ripple ,, if i can;t get the right size capacitor which way is it best to go, up or down in size (uf) derkiow
Old 01-07-2011, 12:26 PM
Al_The_Man's Avatar
I work it out that at 68v a 7200µf will produce 5% ripple at ~4.4amps load.
at 10amps you would need around 16,000µf for 5% ripple.
It depends on your load and the amount of ripple you want to design in at max current.
One down side with going too large on capacitance is it requires an increase in transformer VA.
Old 01-07-2011, 12:34 PM
john_100's Avatar
john_100 is on a distinguished road
Hi derkiow
I just had a look at RS components
and found item 381 - 9194 8200 uF 100V 18A @ Ł34-45 screw terminals
with some values pcb mounting types are less expensive
if for some reason you need to use a number of capacitors to make up the required value
I would use 100 V capacitors in parallel that add up to the value needed
Old 01-07-2011, 01:19 PM
re
So is it safer to go up or down would 6600uf do or would i be better going to 8800uf .The reason i ask is that have some 2200uf capacitors already ,,,,and thanks for the replies derkiow
Old 01-07-2011, 01:22 PM
MrWild is on a distinguished road
UP Always up. The more the better.
Old 01-07-2011, 01:53 PM
Al_The_Man's Avatar
Except if you go too high and your transformer is tightly sized, you can go into saturation when running at maximum current.
What is your estimated maximum current?
Old 01-07-2011, 06:33 PM
i have three drives at 5amps so that will be 15amps and i have a 1kva transformer 45v @ 22amps my idea was to use 4 times 2200uf for each drive..derk
Old 01-07-2011, 10:23 PM
Al_The_Man's Avatar
For a 15a max load at 68VDC you would need 25,000µf for 5% ripple.
100% rating would be 1.3kva and 60% duty cycle would require a .8kva supply.
So it looks like you could go up to 25,000 for 5% ripple.
[IMG] code is Off
Need Help!- Power Supply for HobbyCNC EZ Driver trob4199 Hobbycnc (Products) 3 06-19-2011 08:13 PM
Newbie- What type of power supply for my motors and driver? bead Want To Buy...Need help! 7 06-05-2010 09:20 PM
Power Supply for Driver / Stepper evocube Stepper Motors and Drives 4 11-02-2009 06:29 PM
Some power supply and driver Questions gone4pepsi Benchtop Machines 2 03-21-2007 10:48 PM
Driver, PC LPT and power supply schematicas msnarouz Stepper Motors and Drives 3 07-29-2006 09:11 PM
