Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-05-2011, 12:42 AM
EUnit's Avatar
EUnit is on a distinguished road
Picstep stepper current adjustment
Hey guys. I'm working on a PicStep bipolar stepper driver after I found the idea on fromorbit.com. After some research I found that the functional diagram on the Data sheet of the LMD18245T's showed a similar layout in the schematic I thought I'd ad a little more functionality and customization to the driver. First being the Current adjustment.
The schematic off of 'Fromorbit.com' gives you a resistance value for a predetermined amperage output from .1 - 3A (Max) resistors varying from 200k (lowest) to 6.6k (Max Amps)
Now each Driver IC controls one Coil of the stepper therefore needing two for one stepper driver.
Now I was wondering if instead of having a fixed resistor in place for a set Amperage. Would it be possible to combine the RC(3) pins of both IC's with one Trimpot and using a single 500pF cap to control the current equally on both sides without causing interferance?
Attached is my schematic. Its incomplete but feel free to sugest changes and/or improvements I could do. The Microcontroller is programmed to run the driver in full and half-step modes.
Old 01-05-2011, 02:06 AM
mmcp42's Avatar
mmcp42 is on a distinguished road
I suspect not as it is almost certainly measuring the current not just setting it
so unless your motors were identical and under identical load, it wouldn't work
just my 2p worth u understand
YMMV
Old 01-05-2011, 11:33 AM
EUnit's Avatar
Good point. Although bot IC's are running one motor thus the current draw/load should be identical in both coils BUT to be safe I had an Idea dawn on me while reading your post... Instead of having fixed resistors in place of that. I will solder in two jumpers. One for each IC. That way I can still adjust the current for the motors while keeping both IC's separate but with equal calibration at the same time. At least this will give me some versatility when hooking up my steppers.
Old 01-06-2011, 05:55 PM
James Newton's Avatar
James Newton is on a distinguished road
You do realize LMD18245T's are $15 a pop?
Old 01-06-2011, 07:59 PM
Drools's Avatar
Drools is on a distinguished road
EUnit, the AVRSTMD.com drivers are based upon the LMD18245T. His design uses a trimpot to adjust the current. (1 per coil)
[IMG] code is Off
stepper current draw andrewbishop66 Stepper Motors and Drives 3 06-04-2009 08:59 AM
Current sensing on stepper originator General Electronics Discussion 6 12-01-2006 02:48 AM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 08:30 PM
2A current for 1.25A stepper ACME Stepper Motors and Drives 3 08-31-2004 03:18 AM
Stepper motor current alanhunt General Electronics Discussion 3 12-18-2003 09:58 AM
