Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 07-17-2005, 03:36 PM
Billw is on a distinguished road
Stepperworld fet 3 question
Hi
I have a fet 3 kit and when its power up my steppers wont lock .
Does anyone have eles have this kit ? If so do your steppers lock when you power it up ?
Old 07-17-2005, 08:21 PM
ger21's Avatar
They should be locked up. Is you're control software running? Are you sure everything is wired correctly? Double check, and then check again. From you're other thread about the ballscrews - did it work before you switched to ballscrews? Now the backdriving makes more sense, since the motors don't seem to be powered
Old 07-17-2005, 09:07 PM
*Registered*
HobbyCNC is on a distinguished road
Should lockup even without software running....
Dave
Old 07-18-2005, 01:03 AM
I figured it out , There is a button in the software to enable the motors all the time or just during stepping .
Thanks for everyones help .
[IMG] code is Off
