Hi Group,
I was able to take this industrial robot and interface it through MACH3 using some of my open source design bipolar stepper motor drivers, namely the AE-MDL-STPR8811. I am using three DRV8811 at various currents to drive its three unipolar motors, wired as bipolar. The robot is very strong and it was able to push a rather heavy tool cart as it moved. You can watch a video here:
YouTube - DRV8811 Driven Industrial Arm Robot
The question I have is this. If I want to control the motion coordinates via some form of GCode, since this is not a linear X-Y system (the Z is still as Z as any other configuration), but I guess polar, what is the best way to get the transformation accomplished. Is this something MACH3 does?
Let me explain what is my ultimate goal here. I want to use the robot as a passive component pick and place. Seems like overkill, but since it is working, I figure I might as well use it! On my PCB board tool, I can get a Pick and place file which details the coordinates each component is located, along with its rotation. So I figure I should be able to generate an easy G Code filw with this coordinates.
Except that although each coordinate is easy to reach by moving linearly in the X and Y directions, I must now move radially both arm motors to reach whatever X and Y coordinate I am to move to. Even if I do not need to displace in the Y axis, the robot would need to move both motors to move in a single axis. Hopefully I am making sense here...
Has this been done before? I am kind of stuck, so any insight would be highly appreciated. Thanks!
JIQ
