Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 01-01-2011, 03:06 PM
leeleatherwood is on a distinguished road
SPEED! New Drivers or Different Leadscrews?
Ok, I am building this CNC Plasma cutter. Its running a Hobby CNC 4AUPC rev2 driver, Hobby CNC 305oz Motors and 1/2-10 single start leadscrews and a 36v power supply. It has dual motors for the Y-Axis, gantry weighs about 30lbs.
I am only able to get about 60-70ipm rapids before the motors lock up, I am also getting an annoying mid-band resonance at around ~30ipm that sounds horrible but does not cause any lost steps that i can detect.
My machine is a 4x4 so 60ipm is very annoying, and I also need high speed for the plasma cutting operation of sheet metal.
I am unsure what to upgrade. While using a 24v power supply I can only attain about 40ipm, with 36v that jumps up to about 70ipm. This leads me to believe that some Gecko G201X's will solve my problems by allowing me to run 80v to the motors, this will also allow me eliminate mid-band resonance. BUT I may run into leadscrew whip, on the other hand my leadscrews are supported on both ends.
My other option I see is to switch to 5 or 10 start leadscrews. Since I would need to replace all my Ant-Backlash nuts, Couplings and 12ft worth of leadscrews, this comes close to the price of 4 new G201X's. Would allow me to run slower RPM's, while the torque increase would be nice I dont think I need it since a Plasma machine has no "load" like a router. But this would keep down on the leadscrew whip.
Thanks!
Old 01-01-2011, 03:13 PM
ger21's Avatar
Depending on how fast you want to go, you may have to replace the screws either way, due to whip. My 60" 1/2-8 2 start is only good to about 160ipm before the whipping gets too severe.
Old 01-01-2011, 11:08 PM
James Newton's Avatar
James Newton is on a distinguished road
What is the current rating on the motors and how many amps can the drivers put out? How many wires on the motors?
Old 01-02-2011, 02:08 AM
adel_sebaey1 is on a distinguished road
Good I hve the same idea to do.
Old 01-08-2011, 09:30 AM
Sorry for the late reply.
#23-305-DS8A 425oz-in bipolar rating, 305oz-unipolar rating, 4.2v, 3A, 200 S/R, 3.2mH, Size #23, Dual Shaft, 8 wire
3 or 4 Axis Unipolar Chopper control.
Individual OR simultaneous control of 2/4 Phase Stepper Motors.
Accepts 5, 6, or 8 wire stepper motors only. 4 wire types are not usable.
42VDC maximum input voltage, 12VDC minimum input voltage. 24VDC Minimum Recommended Voltage.
3.0 Amps Maximum per Phase, 500ma (.5A) minimum. Each axis adjustable throughout this range.
1/1, 1/2, 1/4, 1/8, and 1/16 Microstepping.
Notice is says max 42VDC for the controller, but after doing research it seems the max safe voltage is between 38-40vdc, nobody makes a power supply in this range so you have to run at 36v.
Old 01-08-2011, 09:35 AM
Yeah i am currently looking into Rack and Pinion.
Old 01-10-2011, 06:52 AM
vger's Avatar
vger is on a distinguished road
You might take a look at this thread if you haven't already...
http://www.cnczone.com/forums/linear...e_ever_if.html
Steve
[IMG] code is Off
need more speed from computer to drivers 15mgtar Machines running Mach Software 5 07-15-2010 01:23 PM
Keling drivers trippled the speed/power of my machine! Fiero Addiction Automation Technology Products 16 07-21-2008 08:21 AM
leadscrews nickr100 DIY-CNC Router Table Machines 1 01-18-2008 01:55 PM
Leadscrews MrRage Employment Opportunity 2 01-02-2006 05:21 AM
Leadscrews and speed xairflyer DIY-CNC Router Table Machines 6 02-06-2004 07:40 PM
