Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 12-31-2010, 11:12 AM
Robotics Guy is on a distinguished road
How hot are stepper motors supposed to get?
I'm using these motors: 3.6V, 1.8 DEG VEXTA STEP MOTOR-MPJA, Inc. and they get really hot when my machine is running. The z-axis motor gets to about 130f (~55c) and the x-axis 109f.
Is that normal?
My hobby website: www.roboticsguy.com
Old 12-31-2010, 11:28 AM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
The 109f is just getting warm. Does your controller drop the current when stopped? Some of them have a setting for this which reduces current, therefore heat, when stopped for more than a second or so.
Jim
Old 12-31-2010, 01:06 PM
vger's Avatar
vger is on a distinguished road
130 F is not too excessive for most motors. This is most likely the case (frame) temperature. The frame of a stepper is most often the actual laminations of the stator on which the coils are wound. As long as the temperature does not get high enough to damage the insulation on the coils, or cause magnetic degradation in the rotor, the motor will be fine.
Steve
Old 12-31-2010, 01:19 PM
nophead00 is on a distinguished road
Stepper motor current ratings are often for 80C temperature rise with two coils on, so if you run them at full power they will get very hot unless you bolt them to something that can take the heat away.
Old 01-01-2011, 02:36 PM
James Newton's Avatar
James Newton is on a distinguished road
What sort of driver are you using?
Old 01-01-2011, 03:07 PM
Yes, that's correct. I used an IR thermometer, so it would have measured the case temperature.
L297/298 combos.
Old 01-21-2011, 05:24 PM
bagherdn is on a distinguished road
hi
i think 50c isn't so much
it may be overdrived with extra current (don't use chopper?)
usually steppers are used on higher current . i've been running my router motors with double current and they are very hot , but for 3 years no problem with them
[IMG] code is Off
Just IN- Provide controllers,drives,servo motors,stepper motors,electronic parts from China Ling Product Announcements & Manufacturer News 2 07-12-2009 04:10 AM
Problem- G53 g code need a little help is the machine supposed to move? woffler G-Code Programing 10 09-10-2008 12:31 PM
Mastercam Posts. How are they supposed to work? Zak@CWS Mastercam 13 05-03-2008 10:32 AM
Wanted DIY stepper driver circuit for 6 wire stepper motors Colin300 Australia, New Zealand Club house 5 09-20-2007 09:20 PM
Are they supposed to sound like this? cyclestart Stepper Motors and Drives 10 07-07-2007 12:25 PM
