| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello, I have a Terco Milling Machine, it came with sanyo step-syn 103-807-7 motors. They are 1.8 Degree, 1.8 V, 4.8 A. Steppers. They are unipolar six wire with colors White, Black, Brown, Gray, Blue, Yellow/Green, I have searched and found nothing for this. White and Black have continuity. I just got my Gecko Drive in today and would like to wire up my new mill. Any help would be greatly appreciated. |
| you can figure out your leads using an ohm meter. Measure ohms between all of the wires and record the results. You should have 2 sets of 3 wires that have continuity. These sets are your two phases. Within the each phase 2 of the wires will measure twice the resistance between them as the third will beween the other two. The wire that measures half the resistance is your center tap. here is a web page to help explain: Stepper Motors I would connect the two wires with the most resistance between them to A and /A on the Gecko, then connect the two wires with the most resistance form the other set of three, to B and /B. Make sure to cap the centertaps separately. This should get you going. If you need more preformance you might try wiring half coil. |
| Tags |
| driver, gecko, motor, stepper, wiring |
| Step-Syn Stepping Motors Sanyo Denki | Shanghyd | Stepper Motors and Drives | 1 | 01-16-2011 11:47 AM |
| motor wire color in cnc conversion | MPaulHolmes | Benchtop Machines | 13 | 08-09-2009 06:19 PM |
| Wire color code HP laserjet II steppers | rustranch | Stepper Motors and Drives | 3 | 02-13-2005 10:40 PM |
| Wire Color | HillBilly | General Electronics Discussion | 1 | 07-26-2004 12:04 PM |
| Step-Syn from Sanyo Denki | tecno | General Electronics Discussion | 4 | 11-09-2003 06:06 PM |
