Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 12-27-2010, 01:19 PM
euler357 is on a distinguished road
Solved issue with Univelop / CNCgeeker 4/5 axis TB6560 board
I purchased the Univelop / CNCgeeker 4/5 axis TB6560 driver boards (see photo) a few weeks ago and got them working on my new homebuilt CNC router but found that it was missing steps (see photo) and the errors were repeatable and were not speed dependent. After changing nearly every setting in Mach3 and Windows XP, I narrowed it down to the Univelop / CNCgeeker TB6560 driver board.
When a direction change was sent from Mach3 to the parallel port, it was correct but a delay mismatch in the optocouplers on the driver board was causing the step pulse to arrive at the TB6560 IC sooner than the direction pulse. So the motors were turning one step in the wrong way after each direction change!
I have attached a photo showing the step pulse happening before the direction pulse. This is measured at the step and direction pins of the TB6560 IC.
I was able to fix this by swapping a resistor and shorting another. I published the details of this fix on my web site at cockrum.net
ID:	122241   Click image for larger version
ID:	122242   Click image for larger version
Old 12-28-2010, 11:14 AM
James Newton's Avatar
James Newton is on a distinguished road
A perfect example of the kinds of problems people run into with these cheap Chinese drivers. Congratulations on having the tools, knowledge and time to solve this one.
Tags
tb6560 missing steps
[IMG] code is Off
Need Help!- Current setting for TB6560 3-axis board (eBay) leaveme DIY-CNC Router Table Machines 4 06-24-2011 03:55 AM
need help with 3 AXIS (TB6560) CNC DRIVER BOARD Jason Miller General Electronics Discussion 34 01-06-2011 12:25 PM
Univelop 4/5 axis direction issues - Solved yngndrw Stepper Motors and Drives 0 12-16-2009 02:46 PM
Need Help!- univelop 4 axis driver board olddaphon Want To Buy...Need help! 0 04-04-2009 11:30 PM
New Build. Nema 23's and 3-axis Univelop Board HerbalHaze Stepper Motors and Drives 4 10-06-2008 05:00 PM
