| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
With all these stepper motors up for sale, clearly others buy them them apart from hobbyists? I'm checking out photocopier repairers at present and have found a supply of dead photocopiers to raid but I suspect the motors will not be big enough (I need => 400oz/in motors). I'm getting them for nothing so only my time will be wasted. If I find that I have to look elsewhere for wrecked machinery .... what machinery do I look for? Andy |
![]() Printers and copiers more than likely won't have more than 150 oz steppers in them. They only have to move paper. I really don't know where you can find larger ones, other than possibly machinery.
| I've got a nema34 size 500 oz stepper from a A0 size plotter. I believe it was a hp. There are also big steppers used in airplanes like the boeing 747 (fly by wire). Generaly steppers are used in equipment with precise movement.
__________________ ____________________________________ Jeroen |
| Big steppers and big servo motors can be found in commercial sized copy machines like the Xerox 9900. Big machine, lots of parts, servo's, steppers, ballscrews......
__________________ If it's not nailed down, it's mine. If I can pry it loose, it's not nailed down. |
| With Australia being near the end of the global supply chain, (NZ is further down the chain), a re-use mentality makes commercial sense.. I might check out photocopier/plotter repairers here and in NZ a bit more thoroughly and target those who repair the big machines. Thanks for the thoughts Andy |
| jason marsha, Glad to be of some help in your quest for steppers. Sometimes you can cross the part numbers to find out the specs but most times the motors are of a priority type, specifically made for the piece of equipment. Most OEM's of the part won't give you any info on it. Sometimes you can get lucky by contacting the manufacture of the piece of equipment. Good luck.
| Yes the photocopier Steppers will work, but expect very slow movements & lack of power. This is OK if you are contemplating a small precision machine and time is not an issue. I've finally got my CNC machine up and running a few nights ago, this machine uses steppers from commercial photocopiers and I'm already loosing steps as low as 400Hz operating frequency on an old 386 Laptop. |
#12
X-Axis; Sanyo Denki, 4.2 Volt, 1.5 Amp (8 Ohm 20 Watt Resistor) Y-Axis; Minebea, 5.7 Volt, 1.14 Amp (9 Ohm 20 Watt Resistor) Z-Axis; Shinano Kenshi, 8.5 Volt, 0.96 Amp (8 Ohm 20 Watt Resistor) I'm using a 16 Volt 5 Amp Linear PSU with the resistor values as above. The Computer is an old Toshiba 386 Laptop which TurboCNC describes as; Timer Latency; 11.51 Microseconds Max is; 431.00 Min is; 11.00 10% Jitter is; 10363.0 Hz It may very well be a Computer hardware problem, so I've created a thread in the TurboCNC Forum querying the suitability of various Computers I have. |
| stepper motors | Ray Kahuna | Stepper Motors and Drives | 2 | 10-09-2007 06:59 PM |
| Stepper Motors | kellogs72 | Stepper Motors and Drives | 1 | 11-29-2004 07:27 PM |
| Stepper Motors | tinwakr | Stepper Motors and Drives | 1 | 10-29-2004 03:43 PM |
| Stepper motors... | Mikael | Stepper Motors and Drives | 4 | 09-14-2004 04:41 PM |
| Stepper motors | robbycar | Australia, New Zealand Club house | 3 | 06-15-2004 02:35 PM |
