| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello , I need some advice from the pros. I have a bi-polar stepper which is rated for 12V / 0.67A/phase. This motor is supposed to deliver 7Kgf.cm (97.21 oz.in). I am driving this with a L297/L298 combination . I attached a weight to the pulley and tried lifting a dead weight and found a maximum pulling torque of 4kg.cm @ 60rpm. I am inable to go beyond that with this. I am using a 24VAC transformer with a bridge and a 2200uF cap to filter the AC. Is this a valid design ?Where am I going wrong ? I need 7kg.cm atleast upto 120RPM . Can anyone help me ? I will supply any additional info as required . Regards |
| That 7kg would be with a 1cm dia. pulley at 0 rpm. Once it starts spinning, the torque will start to drop. Sounds like you need a bigger motor, preferably with a lower V rating.
hummm no good for 297 298 drivers! these motors are high resistance phase ! + - 10 ohm ?! I recommend you to measure the resistance of 1 phase, and itself is taller than 3 ohms, that motor are not all right for the pilotage in pwm 297 298 . you will also have always a low couple feeding them to 40 volts. visit my site!! hi
__________________ my steppers turn to 17000 step/s, my stepper drivers arrive to more than 50000 step/ses :- ( |
Thanks Ger and all of you for your kind reply. I have measured the torque at a pulley of 50 mm dia. ,where it is lifting about 1.5 kg , hence (1.5 * 2.5 = @ 4 Kg. cm ) . Sadly I have already purchased the stepper and it cannot be exchanged for a lower voltage motor. My only recourse now seems to be to hack a solution. Would increasing the voltage to 36V give me a better torque even at lower speeds ? As per my understanding the only way to get a better torque at a higher speed is to increase the voltage . Would this help for lower speeds too ? |
What I am trying to get across is that, I am trying to see if the motor is meeting its specs , which it is not . It does not deliver the rated 7kg.cm which it is supposed to deliver. Eidos , unfortunately your page is in Italian , difficult for me to comprehend !!!Thanks for your replies and that of others. Regards Thomas |
By couple I think you mean torque , so you say that with L297/L298 I will not get the torque ? My motor's resistance is 17.5 ohms. Do you have any schematic posted on your site , can you give me a link ? Thomas |
#10
#11
Yes the motor holds 7 kg without spinning , but that does not help me much .It is made by a company called srijan drives , but I am not able to get this data from them . have to show it to a customer , where do you think I can get the torque / speed characteristics for this motor ? Would this curve be more or less same for most bipolar motors ? Regards Thomas |
#12
| Mo Torque, | CharlieM | Stepper Motors and Drives | 5 | 05-18-2005 11:13 AM |
| Low torque | swarfmacdaddy | Stepper Motors and Drives | 9 | 12-29-2004 01:47 PM |
| Can I Get More Torque? | cbcnc | DIY-CNC Router Table Machines | 38 | 04-14-2004 03:47 PM |
| Torque ? | motomitch1 | General Electronics Discussion | 2 | 01-26-2004 01:29 AM |
| How much torque | CNCadmin | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 03-31-2003 12:49 PM |
