| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hello All, I Have Damen Stepper Drives, Cant Find anyonline documentation on the boards.. I moved my Machine Yesterday, into a new soundproof box, Now my X Axis is not working Here is wht i have tried: Fresh Install Of Mach3 Onto New Pc Port Correct Ox378 In BIOS & Mach Ports And Pins Motor Is Not Stalled - Plugged X Axis Into Y - Functions Correctly Ports In Mach 3 Are: 3,2 Port 1 & 1 5,4 Port 1 & 1 7,6 Port 1 & 1 Enable1 Yes: Port1 Pin 17 (Stops Sleep Mode) Opened Up Case - Fiddled With Wires to check for loose connection - Cant Find It Power to the board from PSU - Yes Same Voltage As other 2 Steppers Lights: Yes, amber on all 3 No Reds As Far As I Can Tell Its not in 'Sleep' Mode as the other 2 boards are working correctly Checked Ribbon inside case: Yes switched ribbons over etc...ribbons work on other steppers Have i changed anything else in the boards: No not changed any jumpers etc.. its all as i left it I have no idea now what to check for now? Individualy Check voltage of wires coming out of the stepper board Nothing looks burnt, no funny smells, everything else runs perfect... Im annoyed that i cant find the spec sheet on the web! Anyone got an idea before i sledge hammer the thing, my machine has been running fine for the last 2 years, and now its just junk! |
| Boards Looks Like This: DamenCNC - Electronic parts Go Down to: Housing kit for drivers & powersupply The housing is designed to fit the powersupply and ringcore modules offered at this site. Further the housing has a slotted design such that the following drivers will fit. 2.1amp, 4amp,3Dstep,4Dstep,interface (next series will include linisteppers) . The housing is offered in kitform since there are so many configurations possible, so the assembly will require some wiring and soldering skills... |
| Well after digging in deeper.... I have 40v going into the stepper board, and nothing coming out? I have taken the board out of the housing, after looking for dry solder joints, broken parts etc, under a micro scope, i cant see anything wrong with it... Is there anyone i can send it off too? Is there anyone out there :-( |
| board working | ljd10 | DeskCNC Controller Board | 6 | 06-09-2010 08:03 PM |
| Need Help!- Xylotex Board quit working ! | kel1 | Xylotex | 1 | 04-30-2010 03:06 PM |
| Problem- Alexander's PIC 3 Axis Board (Not Working) | Telly | Stepper Motors and Drives | 2 | 03-29-2009 05:01 AM |
| 2 amp camtronics board working | gearcut | Stepper Motors and Drives | 0 | 05-10-2005 10:40 PM |
| Is possible to create my own step board? | samsagaz | General Electronics Discussion | 2 | 03-28-2005 03:24 PM |
