Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 12-09-2010, 02:32 AM
midohamaki is on a distinguished road
why the motor not runing
hi everyone
plz i need help in my controller
i use l297 controller with l298 H-bridge to control 2.5 A unipolar motor
i connect the motor well in bipolar connection and i used the 555 timer to get pulse train 668Hz and it worked very well but
when i use the mach3 to control the motor the motor not running
i tried a lot to solve it but nothing work
1- i isolate the parallel port signal with 74h244 and another time with 74573 and nothing happen too
2- tried to make motor tuning and port configuration in mach3 but zero results
so i do not know where is the problem
plz help meee
Old 12-09-2010, 03:08 AM
no posts for helpin
plz guys i'll appreciate any help
i need your advices
thanks
Old 12-09-2010, 06:57 AM
vger's Avatar
vger is on a distinguished road
What pins are you connecting to on the parallel port?
Old 12-09-2010, 10:24 AM
on pin 4 , 3 on EPP mode
Old 12-09-2010, 11:23 AM
vger's Avatar
Do you have Mach3 configured to use pins 3 and 4?
Is the port number correct in Mach3?
Do you also have ground from the parallel port to ground point on the L297?
Old 12-09-2010, 05:18 PM
yes i configured pins 3 , 4 and the port number correctly
and i do grounded the pp with the l297
what if it about the frequency !!
how can i use specific frequency by mach3 coz motor work well with 1KHz
may be it too fast pulsing from mach3 ???
what do you think ??!!
Old 12-09-2010, 05:32 PM
neilw20's Avatar
neilw20 is on a distinguished road
Answers linked... Been there, done that.
Look at this thread. There was the same problem solved. Read all posts.
http://www.cnczone.com/forums/mach_s...t_running.html
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 12-09-2010, 05:34 PM
thank you sir i'll read it now
Old 12-09-2010, 06:04 PM
i had read the post you told me
and it was have the same problem and i think it was about motor tuning and mine too but how can i customize the motor tuning option to be in specific frequency ??
and i will try every solution in that post and see what is gona happen
Old 12-09-2010, 06:08 PM
neilw20's Avatar
Don't get confused with Mach3 speed, like 25KHz. That is how often it updates the outputs, but they don't change on every update. This enhances timing accuracy.
Go to motor tuning and set motor speed very slow, then keep doubling it until it does not work.
Halve the one that doesn't work, sneak up on the limit, then back off, say 25%.
Once you have the optimum speed set, do the same procedure with the acceleration. Changing direction will not loose steps when you get it right.
Make sure you have the step and direction polarity set correctly according to the specs for the chip you are using.
That is, active high/low in the output pins.
  #11   Ban this user!
Old 01-21-2011, 05:38 PM
bagherdn is on a distinguished road
do step by step
i think at first u must be sure of LPT output (hardware,wire and DRIVER)
for testing it use a small led with a resistor on the selected pins and run mach, if all are ok it will say to you, then u should think on frequency and... if problem is this so ur motor must stall and vibrate with no rotation and u can try for tuning it.
  #12   Ban this user!
Old 01-22-2011, 06:56 AM
at first thnx for ur reply
i am sure of my LPT and tested it it is okay
a bout the freq i donot know the freq i will get from mach3 in spec tuning
so i use 555 timer to get known freq from it and the motor work very will
so i am sure now that the problem in mach 3 tuning
me and my friend made software to control 555 and the driver circuit by code and it worked will but the G code was simple not complex
but i will find the right tuning in mach 3 and tell you it ASP
thnx
[IMG] code is Off
Just got a job runing a cnc laserz 100w trooper55 Laser Engraving & Cutting Machines 3 09-17-2008 06:21 AM
Torchmate 1 up and runing, fine tune issues gfelippo Torchmate 2 07-20-2008 02:48 PM
Runing out of pins? bigz1 Hobbycnc (Products) 28 05-19-2007 06:17 PM
Any one runing Allen B Ultra100 in Step/dir DennisCNC Servo Motors and Drives 4 06-15-2006 09:26 PM
Anyone runing ~2,600 oz steppers? DennisCNC Stepper Motors and Drives 6 05-31-2006 11:05 PM
