| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Hi. Recently I purchased SP705 power suply, M880A driver, 57HS22 stepper motor all from Leadshine and breakoutboard from next image http://img.alibaba.com/img/imagerepo...er2_132260.jpg I will get 5V from USB. Please help me configure driver, wiring motor to driver and configuring EMC2 or Mach3 to do a simple 1 axis test Thank You in advance |
| Err... does the mfgr you purchased the driver, etc... from not have that documentation? Wow... Something has to tell you which parallel port signal goes to which P# on that break out board. If there are no docs, you will probably just have to tell your CNC software to put a signal on a pin, then run some sort of job that exercises that pin and look for a signal with a meter or logic probe down the line of P# pins. Then you need to figure out which pin is which on your stepper motors. If there are no docs, this page may help: Stepper Motor wiring |
I have the documentation. but moor doesen't move a bit I have W7 - 64 bit and mach3. I think Mach3 is not compatible with x64 environement. So i tryít in ubuntu x32 and emc2 but still no result. I think is a wiring problem. |
| Did you find solution to your problem? I am waiting the same board to arrive,your wiring looks ok to me. Did you try to change active low/high setting in mach3? Why nobody connects enable pin on this drivers? |
| How do I connect an old stepper driver with cwp +, - and ccwp +, - to a new break out board with pulse, com, and step? Should I use a flip flop that will send the pulse to cwp + when dir is high and ccwp + when dir is low and connect cwp - and ccwp - to com? Also, does anyone know if and how I can add optical feed back into my breakout board? I'll attach photo's of my breakout board and stepper driver with labels. I also have some other questions I have posted in my blog and would appreciate any help or direction, so please feel free to visit my blog on my punch press project. Last edited by Brainfreeze; 02-26-2011 at 01:59 PM. Reason: Though of more to add. |
| Stepper driver, breakout board problems | dougie329 | DIY-CNC Router Table Machines | 33 | 08-16-2011 04:59 AM |
| Help Newbie convert wiring from DSP to breakout board | JohnCo | Australia, New Zealand Club house | 2 | 11-03-2009 01:11 AM |
| Need Help!- does this driver need breakout board? | dreamci | General Electronics Discussion | 2 | 09-30-2008 04:49 PM |
| Wiring Breakout Board Questions | Dingo745 | Xylotex | 14 | 03-31-2008 02:47 PM |
| Stepper Driver, Controller, Breakout board, Home switch, ????? | perolalars | General Electronics Discussion | 4 | 10-28-2007 09:35 AM |
