| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
Tore my mill down to upgrade some of it (Solsylva 13 w/ fully supported X) and everything worked perfectly fine before I tore it apart. Got it back together and noticed that on my Z when I move up and down there was a delay, it turns out that the shaft moves about 1/4" thru the motor before it catches and then moves the axis, is there a way to tear into it and possibly fix? Then on my X axis, the motor will stutter when you try to move it, I've tried every speed possible, and if you are manually controlling it and hold left it will move left, then let go and hit left again, it will go right, and you can hit left a third time and it will go left. Sometimes you can hit it two times and it will go the correct direction and on the third it will go opposite. At first I blamed the driver, but the motor will not work on a known good axis, and the X axis drives known good motors just fine as well. Any ideas guys? Thanks in advance, Taylor |
| Taylor, Most stepper motors have a bearing cup on the back end that has one or more spring washers pushing the bearing against the rotor. If you push on the shaft, the spring washers flex and allow movement. Taking the stepper apart will most definately ruin it. The rotor will lose part of its magnetic strength and make the motor very weak. Your lead screw should have it's own bearings set up to restrict linear movement of the screw. This way the motor only sees rotary torque and no linear force. It sounds like your X axis may have TOO much friction to turn the screw. With the motor not mounted, you should be able to turn the screw with your fingers. Perhaps your nut is not aligned or too tight. Steve |
Thanks for the help so far. |
| shaft play with smaller bearings | bmurph | Mechanical Calculations/Engineering Design | 11 | 03-07-2010 06:47 PM |
| How to cut stepper motor shaft? | harry11733 | DIY-CNC Router Table Machines | 3 | 07-25-2008 10:01 AM |
| Stepper motor with 6mm shaft? | juzwuz | Stepper Motors and Drives | 6 | 03-23-2008 02:19 AM |
| Stepper Motor, 6mm shaft | juzwuz | Want To Buy...Need help! | 0 | 12-20-2007 03:38 PM |
