Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 11-03-2010, 02:41 PM
mrbasher is on a distinguished road
Did I get a good deal on these Steppers? :)
Hi all,
I was out today at lunch foraging through the local electronics "surplus" store and found what looked to be some pretty nice stepper motors for $19 each...
Specs: http://www.linengineering.com/LinE/c...s/pdf/5718.pdf
Lin Engineering
Size NEMA 23
Model 5718L-04P
Amps 6.50
Torque 294.0 oz-in.
Step 1.8 deg.
From what I could find online they seem to be much more expensive than what I paid... I picked up three of them just because, but they must have had 20 or more of them there. I assume they are used, but they don't have a mark on them.
Old 11-03-2010, 04:37 PM
Dorsal is on a distinguished road
So, who did you get them from? Name? Address?
The voltage requirement to drive those motors in series ( 32 x the sqrt of the inductance) is 32 X (sqrt 1.3) = 36.48 V so power supplies and controller cards won't be an issue at all.
Old 11-03-2010, 04:46 PM
ger21's Avatar
That's a good price, but the problem is that you'll need more expensive drives to supply the 6.5 amps.
Up to 3.5 amps, you can use a Gecko G540 which is about $75/ motor.
To get the 6.5 amps, you'll need a Gecko G201X which is $114/ motor.
If you buy a G540 with motors, similar power motors are about $40 each, but you get the G540 for $50 less.
So, bottom line, is if you already have the drives for them, it's a really good deal. If you don't have the drives, it would have been cheaper to buy a G540 and new motors.
Old 11-03-2010, 04:52 PM
Oh yeah - I forgot to look at the Amps / phase number.
Old 11-04-2010, 09:08 AM
Thanks guys
So is there any advantage to using a motor with a higher amp rating?
Also, the motors were at a place called Vetco in Bellevue, WA.
I might have a line on getting some of these: http://www.motionshop.com/pr/lineng-RMS2.shtml but I'm still waiting for the guy to email me back...
Old 11-04-2010, 10:21 PM
H500 is on a distinguished road
A high amp motor is not as good as a low amp one of the same torque because you will need a more expensive driver.
Old 11-05-2010, 02:16 AM
Gold Member
RomanLini is on a distinguished road
Higher amp motors also have significantly lower inductance and will be more prone to resonance problems when used at low speeds due to the much higher excitation energy per step.
I would consider anything more than 3A/phase in Nema size23 as possibility of being problematic motors at low speeds. Those motors may have even been sold off as surplus because of resonance problems.
[IMG] code is Off
wow, somebody got a good deal KTP Laser Engraving & Cutting Machines 2 12-31-2009 09:35 AM
Need Help!- IS THIS A GOOD DEAL?? nickb730 Want To Buy...Need help! 4 07-02-2008 08:23 PM
Newbie- Good deal? geales1989 General Metal Working Machines 0 04-06-2008 08:15 PM
Considering used laser: is this a good deal? SimonArthur Laser Engraving & Cutting Machines 1 01-23-2008 10:01 AM
Good Deal or Not? DroopyPawn Benchtop Machines 31 12-03-2007 08:36 AM
