Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 10-28-2010, 12:07 PM
dsmskyline is on a distinguished road
Motor Identification Help
First off I want to say this place is great! Ive lerked for a while but just registered.
I have aquired a couple of 1.8*/step motors. Unfortunately, I cant seem to find much information about them.
There is a tag on the back,
ca244-06140
STP-58d5005-03
1.8*/step 0.5 ohm
03994G
The motor is a square nema 23 frame, 4 wire motor; yellow, red, peach, and tan. Yellow and red and peach and tan are twisted pairs.
Anyone have any insight on this motor?
Thank you for your help,
Thomas
Old 07-22-2011, 09:31 AM
moises is on a distinguished road
Talking
I need your help, please!!!!!!!!!!!
ca244-06140
STP-58d5005-03
1.8*/step 0.5 ohm
03994G
Moisés from Brazil
Old 07-25-2011, 03:39 AM
Gold Member
RomanLini is on a distinguished road
Are you still looking for info?
It's a bipolar motor as it has only 4 wires. The 2 phases are in two pairs, which you can confirm with an ohmmeter. They should be the same as the twisted pairs.
The label says the motors are 0.5 ohm, and the total dissipation in watts per phase will be the same as other square stepper motors of the same size and length.
Once you find out watts per phase (by comparing with other motors) you can calc volts and amps based on your 0.5 ohms spec that you already know.
Hope that helps!
[IMG] code is Off
Bridgeport motor identification cruzin Bridgeport/Romi Lathes 15 09-23-2010 04:39 AM
Syil Super X3 stepper motor identification fbmstar Syil Products 3 05-22-2010 01:05 PM
Newbie- CNC identification 777string Benchtop Machines 9 01-30-2010 07:54 AM
3 phase motor identification?? jevs General Electronics Discussion 1 02-27-2005 09:40 PM
Servo motor identification help kong General Electronics Discussion 28 04-01-2004 03:28 PM
