Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 10-22-2010, 07:51 AM
Rob37 is on a distinguished road
Stepper Motor Question
I built a basic 3 axis cnc and I am driving it with 1/2" acme 10tpi rod. which stepper motor out of the following three will give me better torque. 425oz-in 387oz-in or 382oz-in all nema 23 motors from keling.
Rob
Old 10-23-2010, 04:22 PM
Well I ordered my steppers today and I chose the 382 oz-in with a 24volt 16 amp power supply. With my 1/2 inch 10 tpi ACME lead screws I should have plenty of lift for the Z axis and plenty of torque for X and Y movement as well.
Old 10-23-2010, 04:25 PM
ger21's Avatar
What drives are you using?
When using 1/2-10 acme, you won't get a lot of speed, because they need to spin too fast. At slower speeds, though, you'll have plenty of torque.
Old 10-23-2010, 05:15 PM
Thanks for the vote of torque confidence Gerry. My first cnc is not going to be a speed demon as I need to learn much about cnc before I get crazy with it. I don't care if it takes a bit longer to cnc something at this point I have much to learn. A Photo of my machine below. I call her Ugly Betty 1. She's ugly but she's mine.
Old 10-24-2010, 08:37 AM
vger's Avatar
vger is on a distinguished road
If I might make one tiny suggestion to you... You might want to stiffen up the pieces that support your bridge. When the mass of your Z axis assembly starts or stops rapidly, you may have some flex there. A piece of angle with some more MDF attached would probably do the trick.
Steve
Old 10-24-2010, 09:23 AM
Steve
Thanks for the heads-up on the gantry. Yes I agree that it will probably flex a bit under load. I chamfered and bolted two full 3/4" pieces together under the 1" aluminum angle that you see in the picture. I am hoping that the flex will be minimal as I intend to use this machine to cut better parts for a better designed machine.
Rob37
Old 10-25-2010, 07:00 AM
vger's Avatar
Rob,
The area of concern to me is the vertical end pieces. I marked up your picture... The flex points are along the red lines, the proposed stiffeners would be in line with the blue lines extending out from the surface making the end plates into a sort of a C channel.
Steve
Old 10-25-2010, 07:01 AM
vger's Avatar
oops... forgot the pic...
Old 10-25-2010, 07:14 AM
OK I see what you mean. Great point, I will definitely have to take that into consideration. Thanks for the much needed input.
Thanks Steve
Rob37
[IMG] code is Off
Need Help!- Stepper motor question QSPSB Benchtop Machines 9 09-24-2010 09:27 AM
Newbie- Stepper motor question Almaz Stepper Motors and Drives 1 10-05-2008 05:51 PM
stepper motor of x4+ and another question ataxy Syil Products 0 09-07-2008 11:24 PM
Stepper motor question alexis221 Servo Motors and Drives 3 10-05-2007 08:29 PM
stepper motor question starCNC General Electronics Discussion 5 05-04-2004 05:06 PM
