Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 06-23-2005, 07:09 PM
rweatherly is on a distinguished road
HobbyCNC or Xylotex Driver Kit?
I have unipolar stepper motors (2 Amp, 4.5 Volts, 6 wires) that I need a driver for. I want a kit, and am looking at the HobbyCNC and Xylotex driver kits, which look about the same. Is there an advantage of one over the other, or is there a better choice out there than those two?
Thanks,
Richard
Old 06-23-2005, 09:33 PM
ger21's Avatar
They are basically the same thing.
Old 06-24-2005, 04:07 PM
pminmo's Avatar
pminmo is on a distinguished road
ger21, they do have differences even though they use the same driver.
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 06-24-2005, 08:54 PM
ger21's Avatar
Phil, could you elaborate a little? I have heard that the HobbyCNC can be a bit noisy, but haven't heard anything about the Xylotex.
Old 06-24-2005, 09:19 PM
pminmo's Avatar
I'd prefer not too, don't want to take sides, the information is in each manufacturers webpage, so I cut and pasted both here:
HobbyCnC:
3 or 4 Axis Unipolar Chopper control. NO "Ballast" resistors required!
Individual OR simultaneous control of 2/4 Phase Stepper Motors.
Accepts 5, 6, or 8 wire stepper motors only.
44VDC maximum input voltage, 12VDC or 24VDC minimum input voltage depends on fan voltage used.
3.0 Amps Maximum per Phase, 500ma (.5A) minimum. Each axis adjustable throughout this range.
1/2,1/4, 1/8, and 1/16 Microstepping .
Step and Direction Control.
3.5" by 6.8" double sided with top silkscreen and thru plated holes PCB.
Power On Reset.
On board voltage regulation for 5-volt logic with 12VDC or 24VDC cooling fan from motor power supply.
On board connections for home and limit switches with 10K pullup resistor provided to each. No need for a separate "break out" board.
Minimum of components to make assembly fast and easy!
Works with Step and Direction software such as DeskNC, TurboCNC, Mach2, etc
Xylotex:
4 Axis Unipolar Drive (uses 5, 6 or 8-wire motors)
Upto 44VDC, and 3A/Phase (34VDC +/- recommend, which is the ouput of a 24VAC rectified/filtered tranformer based supply)
1/16th, 1/8th, 1/4, and 1/2 step modes set with jumpers
Onboard RC filtering with HCT541 line buffering for STEP and DIR lines
All unused I/O ported to Screw terminals. 10K pullup on inputs (if resistor installed)
ENA# (axis disable) with user supplied switch and Diodes furnished with board.
DB25M connector for direct attachement to PC Parallel Port Extension Cable
On board DC-DC converter for logic power AND can be used for 100mA 5V fan (fan not supplied with kit)
Motor current set by potentiomenters
On-board reset circuitry
Heavy 2.5 oz. copper circuit board.
Perfect for HF Mill/Drill retorfits, and many Homebrew projects
The text in red is directly related to the Allegro SLA7062 Stepper drivers each use.
Phil
Old 06-24-2005, 10:54 PM
DieGuy's Avatar
DieGuy is on a distinguished road
One good thing about either is the ease of finding a transformer that makes sense price wise. Like this 24V 10A one for under $20
http://www.mpja.com/category/Transformers/24V_CT_(12-0-12)10A_TRANSFORMER_7846_TR.asp
Old 06-25-2005, 07:53 AM
Do you need a capacator with the transformer?
Old 06-25-2005, 08:07 AM
FYI's to others that might be interested, I rec'd this via PM:
The Xylotex has input filters, the Hobbycnc doesn't. That is a plus in two methods. One the input filters by nature isolate the SLA7062 (motor driver)from the PC. That will give the user more protection if that part were to fail. two reduces the susecptibility to noise. i.e. incorrect steps.
The sender indicated that he had no affiliation with either company.
Richard
Old 06-25-2005, 08:14 AM
ger21's Avatar
You need a capacitor and a bridge rectifier. HobbyCNC has a driver kit that includes everything but the transformer. (and case)
Here's some basic info on building a power supply: http://www.campbelldesigns.com/how-t...wer-supply.php
Old 06-25-2005, 08:32 AM
Thanks for the power suppy link. Things are starting to make sense.
HobbyCNC does have a package (you suppy transformer and case), but their packages include the stepper motors, which I already have.
  #11   Ban this user!
Old 06-25-2005, 09:46 AM
pminmo's Avatar
Basic schematic
http://pminmo.com/simpleps.htm
Phil
[IMG] code is Off
HobbyCNC Unipolar Chopper Driver Kit! HobbyCNC Product Announcements & Manufacturer News 1 11-09-2009 08:40 PM
HobbyCNC vs Xylotex (prices) Chunky General Electronics Discussion 0 06-14-2005 08:46 PM
what voltage? i'm confused.. Stepper motors + driver board from hobbycnc Loterus Hobbycnc (Products) 8 01-26-2005 07:10 AM
Xylotex or Gecko step driver for my Mill/Drill? pfeist General Electronics Discussion 10 07-20-2004 01:42 AM
Help with HobbyCNC Driver Clyde General Electronics Discussion 8 04-23-2004 01:53 PM
