Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-24-2010, 02:10 AM
zaebis is on a distinguished road
Need serial port 4th axis stepper solution
I have a manual indexer that I would like to convert as a 4th axis. I would like to use it in conjunctions with other axises or as a standalone unit. I was thinking about a serial port connection with a driver so that I can connect it to the same computer that runs mach3 but use it (potentially) with a standalone program of its own (that I can write in VB to control the card)
Indexer is to spin 6" chuck so it is quite heavy.
So my questions are:
1/ what are the good choices for stepper motor
2/ I will need a driver as driver to serial interface cards I suppose any recommendations? Is that http://store.qkits.com/moreinfo.cfm/KTA-190 something I may be using?
Thx
Old 09-24-2010, 06:27 AM
kineticstep is on a distinguished road
If you can use USB instead of serial, the Teensy http://www.pjrc.com/teensy/ (an AVR dev board) is more capable than the board you linked to, although you would have to program it using C since it is not specifically made for controlling steppers. There is sample code to make it appear as a serial port to software on the PC. The code you would need to write would be reading the data coming into the dev board and turning that into the pulses/timing that is fed to the motor driver(s).
I'll plug my Canadian stepper motor site which may have a motor you're interested in: http://kineticstep.com
[IMG] code is Off
Finally a better solution instead off parallel port veteq Machines running Mach Software 0 03-16-2010 04:46 PM
Serial port to USB in VB.NET DennisCNC Visual Basic 1 12-07-2008 12:02 PM
Stepper Driver and serial port kylemp Stepper Motors and Drives 1 01-27-2008 07:11 PM
serial port lamicron Computers and Networking 9 12-18-2007 10:42 AM
USB to serial port stampman Machine Problems, Solutions , Wireless DNC, serial port 7 12-30-2006 01:17 PM
