| Stepper Motors and Drives Discuss stepper motors, drivers and related topics here. |
just bought 6 japan servo KH42JM2B186 and now i'm starting to build a driver and cannot find a circuit that would work with the voltage in the data sheets i found. I may be overthinking this and it just be as simple as any driver, but i am budget limited and do not want to keep blowing drivers or motors. |
| So what is the voltage in the datasheet? Actually, nevermind. It's the current flowing through the coil that matters, so as long as the driver you use regulates current, and you limit it to the max current rating on the datasheet, you will be ok. So what is the /current/ rating per phase in the datasheet? |
| http://www.japanservo.co.jp/digital/.../pdf/KH42J.pdf According to this datasheet I found, it looks as though I could be anywhere from .5 to 1.2 amp cannot figure out if I'm a 901,902, or 903 but I am unipolar. From what your saying, I gather voltage does not matter much as long as the amps do not go to high and burn out tue motor windings? |
| Well, there is typically a maximum rated voltage, but if you know the rated current, and you measure the ohms through the coil, you can find that E=I/R where I is current and R is resistance. And since most drivers will regulate current (not voltage) that is the spec you really need. Grab your ohmmeter, or buy a cheap one if you haven't already, and measure the resistance of one coil. Then you can lookup what motor you have by checking the "winding resistance" line on that datasheet. BTW, that motor will do well with the Linistepper driver. I'm adding them to the list of good motors. http://techref.massmind.org/techref/...tep/motors.htm |
| thank you very much. I also looked at you techref site and noticed you had them on there without a price. I found them on ebay and they were very cheap. http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT |
http://techref.massmind.org/techref/...index.htm#kits Oh, hang on... that ebay link is for a motor... LOL... I don't sell motors. I just have a list of motors that I know work ok with the Linistepper. The Linistepper is a FOS (Free Open Source) design, but I DO sell a kit for the driver. |
| You would want to setup the current sense resistors as 2 ohm, instead of the 1 ohm supplied with the kit so it will current limit to a half amp. If you buy a kit, there are resistors available to tune the kit for 2 amps, which is the direction most people want to go, but those same resistors can be connected in series so as to make a 2 ohm resistor and tune for 1/2 amp. |
| Newbie- Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver? | joprinz | General Electronics Discussion | 4 | 04-28-2011 03:57 AM |
| Did anyone use this driver? | heyecan | Open Source Controller Boards | 0 | 08-15-2010 11:23 AM |
| Newbie- driver | MR MOTION | General CNC (Mill and Lathe) Control Software (NC) | 0 | 04-09-2009 07:57 AM |
| single axis driver and a b.o.b.,or multi-axis driver board | .xXACEXx. | Stepper Motors and Drives | 3 | 07-02-2007 11:13 PM |
| STEPPER DRIVER FAQ {Stepper/driver amp per phase match. | huios | Stepper Motors and Drives | 0 | 08-27-2006 08:43 AM |
