Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-13-2010, 02:09 PM
Sabrina_B is on a distinguished road
Hardinge superslant x axis brake is on
We just bought a hardinge superslant sb 3 gn 1986. We had to convert it to a 230 from a 460 to power it on. After using jumpers to convert it, we powered it on and it came on. However, we have an alarm that wont let the x axis move or anything for that matter. The alarm is 2008 x axis brake is on not ready. Help!!!!! We got a wiring diagram from Johnson electric coil company and there engineer told us how to convert it. Don't know if it was right, but it did power up fine and the phasing seems to be correct cause the fans are going in the right direction.
Old 09-14-2010, 09:27 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
You might have better luck getting an answer to your question on the Hardinge lathe forum rather than on this, the stepper forum.
Mark
Old 09-14-2010, 09:31 AM
Yeah, i have posted this in several spots cause you never know who might be looking where.
Old 09-15-2010, 09:58 AM
wendtmk's Avatar
Moderator
Cross posting the same post to different forums, especially ones that aren't the correct ones is a bit of a no-no. A single post, to the correct forum, is a much better solution than shotgunning the post to different forums.
Mark
[IMG] code is Off
Need Help!- Hardinge Superslant SB3 GN 3 Axis Lower Turret LMartin Hardinge Lathes 18 09-17-2010 09:42 AM
Need Help!- Hardinge superslant x axis brake is on Sabrina_B Fanuc 0 09-13-2010 02:06 PM
Hardinge Superslant retrofit kudos LinuxCNC (formerly EMC2) 5 04-05-2010 06:04 AM
Need Help!- 4-axis Hardinge superslant homing alarm artin5 Hardinge Lathes 0 01-29-2010 01:51 PM
