What drives are you using, and what are the motors' rated voltages?
I have 3 steppers
(2) 1200Oz. in - 6.0Amps DC per phase (2 phase)
(1) 270Oz. in - 2.8Amps DC per phase (1 phase)
I'm having 70.7VDC running through, do i need any type of resistor on the small motor?
thxs
William Desrochers - Excalibur Creations & Recognition
Raster Bitmap to Vector Conversion Service
270Oz in. ( 3.75 rated Voltage)
1200Oz in. ( 2.7 rated Voltage )
I'm using Gecko Drives G201.
I got all the motors from Homeshopcnc: http://www.homeshopcnc.com/page3.html
No, but use the proper current limit resistor on each Gecko.
The 1200 oz motor might get pretty hot due to the higher voltage. It really should have about 60V max.
