Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Stepper Motors and Drives
Stepper Motors and Drives Discuss stepper motors, drivers and related topics here.
Old 09-08-2010, 07:42 PM
RRRoamer is on a distinguished road
Help with stepper motor specs
Folks,
I have a EAD LA34AGK-26R stepper motor I picked up from work (they were tossing it as it was an unneeded spare...). It's known specs are:
EAD LA34AGK motor
NEMA 34 class
Hybrid motor
Unipolar
4.7 ohms across the coils
2.35 ohms from center tap to ends of each coil
Operated on 90V power supply previously
I could find a bit of information on the LA34AGK-?? class of motors, but nothing on the -26R motor. They specs are all over the place, so I can't use a "good enough" call. Also, the coil inductance is unknown and do not have the test equipment to measure it. (I really need to pick up a decent LCR meter...)
Obviously, the original stepper drivers did not hold the coils with 90V across them. Does anyone have any idea what the holding current should be on something like this? I would really like to get this thing running doing something as it appears to be a pretty good motor. In it's previous life, it was rotating an arm on a piece of semiconductor processing equipment.
Thanks for the help!
--RRRoamer
Old 09-12-2010, 05:33 AM
lucas is on a distinguished road
The LA34AGK-2 has a resistance of 0.85 ohm, current = 3 Amp
The LA34AGK-4 has a resistance of 3.30 ohm, current = 1.6 Amp
Your -3XX motor with a resistance of 2.35 sits in between the 2 above.
So an educated guess would be something around 2 Amp (probably a bit more).
I would start to use it with a setting of 1.6 - 1.8 Amp and see how it works, especially monitor the motor's temperature, if it stays cool then increase the current settings.
Note that the above is for unipolar, you can extrapolate the same way for bipolar.
The R in the suffix means rear shaft option.
Done similar approaches several times with succes.
hope this helps.
Old 09-12-2010, 11:51 AM
Thanks Lucas!
--RRRoamer
Old 03-31-2011, 04:32 AM
danysan2525 is on a distinguished road
specs needed
i have a motor la34bjp-03r, it the only information i have. the resistance on the coils give 0.6 ohm. it has 8 wire.
can someone give some help i can`t find any information about this motor
[IMG] code is Off
Vexta Stepper Motor Specs met4life Stepper Motors and Drives 9 03-05-2011 01:19 AM
Need Help!- Need specs on stepper motor...? scientizt Stepper Motors and Drives 6 08-04-2010 08:40 AM
Need Help!- Pittman Stepper Motor Specs rjhinton Stepper Motors and Drives 0 06-11-2010 10:33 AM
Newbie- Stepper motor specs Joshua General Electronics Discussion 1 03-10-2009 07:53 AM
Nema 34 stepper motor specs? cncmad Stepper Motors and Drives 2 07-22-2008 11:57 PM
